GoPro playback on XBOX one stops and buffers every few min
Running XBox One with the latest player installed and running plex server version 1.13.4.5251 from a NAS. When I play GoPro videos, the video will play fine for a couple of minutes, then buffer for a minute and start playing again. The XBox and Server are both using wired networking. Movies and other content play fine.
I have played the same GoPro content from the Roku player without issue.
Any tips tricks to smooth this out?
What is the resolution of the file?
Data rate: 29955kbps
Total bitrate: 30083kbps
Frame rate: 59.94 frames per second
Any Updates? Going to install the latest release and see if that helps…
This is still a problem… any feedback?
Hi there. If you’re still seeing the same issue with the latest update could you enable logging in the app, and then grab some server logs? A sample file would also be helpful.
