When Plex updates it is unable to locate the TV show Gotham from my library. My folder/filename naming is as follows
TV Shows\Gotham\Season 03\Gotham - S0301.mkv
Try this: TV Shows\Gotham\Season 03\Gotham - S03E01.mkv with an “E” to denote episode.
It works for me every time on all of my TV shows.
You have it looking like it could be season 301 and not season 3. Try using TV Rename or FileBot to rename the TV shows. If you use Sonarr or SickBeard/Rage, they have the right naming scheme too.
Cheers mate. Completely overlooked the E. Cheers.
Most of the time when shows aren’t found like this, it’s an issue with the name. Glad you got this sorted out.
