Has anyone else find that when loading up new TV Shows onto the Plex server episode 3 is never found.
I have loaded multiple tv shows and everything is named correctly all episodes are found EXCEPT episode 3 every time.
Is there a fix for this?
By the way this has been happening for over 3 years.
How do your file names look like?
How do the folder names look like?
Have you ever experimented with .plexignore files?
If you are using names with things like “episode 3” in the file name then your naming is probably at fault. Plex is VERY persnickety about naming. The required format is:
TV Shows <— The library points here
---------TV Show Name (Year first aired if needed) <— This folder holds the season folders
------------------Season 01 <— This folder holds all the episodes for season 01
-------------------------ShowName - s01e01 - Episode Name.ext
-------------------------ShowName - s01e02 - Episode Name.ext
-------------------------And so on for the rest of season 01
------------------Season 02 <— This folder holds all the episodes for season 02
-------------------------ShowName - s02e01 - Episode Name.ext
-------------------------ShowName - s02e02 - Episode Name.ext
-------------------------And so on for the rest of season 02
------------------Season 03 <— This folder holds all the episodes for season 03
-------------------------ShowName - s03e01 - Episode Name.ext
-------------------------ShowName - s03e02 - Episode Name.ext
-------------------------And so on for the rest of season 03
---------2nd TV Show Name (Year first aired if needed) <— This folder holds the season folders
-------------------------2nd ShowName - s01e01 - Episode Name.ext
-------------------------2nd ShowName - s01e02 - Episode Name.ext
-------------------------2nd ShowName - s02e01 - Episode Name.ext
-------------------------2nd ShowName - s02e02 - Episode Name.ext
-------------------------2nd ShowName - s03e01 - Episode Name.ext
-------------------------2nd ShowName - s03e02 - Episode Name.ext
Note: The year after the show name is only normally needed or desired if there is more that one show with exactly the same name. Check http://thetvdb.com/ if you are not sure and match exactly the name used there. There are some exceptions to this where the year is needed even if there is no other show of that name or if the show does not have the year in TheTVDB.
There are naming methods other than the above that work but this does work 99.9% of the time.
If you are going to use Plex it is best to use the proper naming conventions so Plex makes the best match possible. Trying to force Plex to use other naming methods is just asking for frustration.
https://plexapp.zendesk.com/hc/en-us/articles/200220687-Naming-Series-Based-TV-Shows
But it is up to you. You can give in and follow Plex’s rules or you can choose to fight the great Plexosaurus. If you choose the latter your metadata could end up looking worse than Tokyo at the end of the original Godzilla movie. (Gojira)
I got all my files named appropriately as per the guidelines. All other episodes are found without issue only episode 3 gets skipped every time. See attached photos for reference.
Well it “could” be the local media assets are messing things up. In your web browser open settings and click agents. The under both movies and shows for Plex Movie and theTVDB grab “Local media assets” and drag it below everything else.
Also your naming is close but not spot on. Try inserting a “-” between the show name and the SxxEyy section. Plex uses the “-” to help find the break. It should look like “ShowName - SxxEyy.MKV”
Nah tried it all and still no episode 3. File is there works with direct play no problem but server will not find it. Tried renaming. Moving around to different folder. Nothing seems to work. Funny thing is it’s happened to many other series as well.
I repeat my question: Have you ever experimented with .plexignore files?
Look for them high up in your folder hierarchy. Don’t try to find these files with you iOS app. Use the terminal window.
Have you changed the order of agents like this: (If not, please do it)
Go to Settings - Server - Agents - Shows - TheTVDB
In there, grab the line ‘Local Media Assets’ with your mouse and drag it downwards, so it ends up being at the bottom of the stack of active agents.
Repeat the same under
Settings - Server - Agents - Shows - TheMovieDatabase
Settings - Server - Agents - Movies - Plex Movie
Settings - Server - Agents - Movies - TheMovieDatabase
Have you ever tried to perform the Plex Dance ?
