I have a problem that I expect many have. I have many series of shows. Like Game of Thrones. I have season 1 and all five disc. When I open Plex it shows disc one and two. Not the next three. Season 2, it shows one and three. None of the rest. This happens in many places when I look for them on plex. Not just the Game of Thrones. Is there some simple thing I am missing? Thanks
It’s almost always in the file naming and the folder organisation.
- Look up your show on TheTVDB
- Take the title as it is used on TheTVDB. If there is something in parentheses, take that too. If the title contains invalid characters (depends on your file system), like
§ : % *, simply leave them out. - Check the naming and the folder structure of your show. Name the top folder of the show exactly after the title on TheTVDB. No abbreviations. No additional subfolders. No aliases.
- Name the episode files according to the above linked naming guide. Use the same title as for the top folder.
Show's Title - s01e01 - additional info.ext(’- additional info’ can be left out) - After you corrected the naming and folder structure, perform the Plex Dance with all files for this show.
Sometimes, your files are in the mp4/m4v format.
If they are, they could contain internal metadata which can potentially throw off Plex’s scanners.
To avoid such troubles, go to Settings - Server - Agents - Shows - TheTVDB
In there, grab the line ‘Local Media Assets’ with your mouse and drag it downwards, so it ends up being at the bottom of the stack of active agents.
You can mass-rename a whole series at once with software like Filebot
