Great Plexamp update with a few questions
Hats off for the Plexamp team for a another great update! :tophat: hats off!
The possibility to modify your Home Screen is great.
Sonic Sage seems to be an exciting addition, it created a playlist with all fine tracks.
  1. Saving queues as a playlist from Sonic Sage makes the need of sub-folders (Can you add Playlist folders to PLEX or for PLEX PASS users?) more than ever. I saved a few Mixes for you, created my own playlists and now when saving a queue from Sonic Sage as a playlist is creating long list of playlists where scrolling is needed. Organizing them in (sub-)folders is the solution :wink:
Plexamp in my own language feels more comfortable and pleasant.
  1. I noticed a few small glitches in the Dutch translation and modified them on Transifex (Plex Labs localization | Transifex), will they be synced in a future version?
  2. What does “Use GPT-4 When Available” mean (Higher quality, but more expensive).
  3. When selecting Light Theme (Whiter shade of Pale) results in a unreadable / no contrast Plexamp on my iPhone (13), see:
How did you get Sonic Sage to work? I am on IOS and MacOS and can’t get it…I added API key and also have TIDAL integration turned on. Could you provide steps and/or how-to by chance?
Have you clicked the search button?
Then you should see Sonic Sage.
Right, yes. but do not see that at all. only see recent searches… :frowning:
And when you clear the search and click on the white screen?
Not sure what you mean white screen, but nothing. Makes me wonder if there’s something wrong with the api key? hmm…
When you clear the search field it will show you a blank screen. Tapping there ends up with the Sonic Sage.
At least in my iPad / IPhone.
Just learned that a “Tidal Only” version is coming in the next release. So that’s why it’s not working for me, I only have Tidal and no local file library :slight_smile: thanks!
