Personally I do not like it and wish it was 100% transparent. Doesn’t help it looks very blocky with no even colour shift.
Maybe allow us to manually set the transparency with a slider?
i agree with the grey, dont like it at all, but dont agree with your comment to make it 100% transparent aka non existant - it would be very hard to see the OSD depending what is playing
make it transparent black like it currently is and in other plex apps.
I think a slider would be an option. Then I can set it to say 10% transparency / opacity and you could set it to say 50%.
I’ll try. I’d really prefer there was no tint. I really don’t like it affecting my picture quality until the OSD disappears.
Best picture I can get. Plasma so I notice these things. This is with a black background.
Please just remove the tint. It’s awful.
EDIT: I can see all OSD text clearly without the tint so this is purely a aesthetic choice on Plex’s part. One that I think does not add to the experience.
@sixones thank you for the latest beta. The black is a huge improvement!
Glad to hear it’s working better. If the issue is solved, do you mind marking this thread so? Thanks!
