Grey tint on new OSD GUI
Personally I do not like it and wish it was 100% transparent. Maybe allow us to manually set the transparency with a slider?
This was changed from grey in colour to black after I requested it a while back.
Could we get a discussion going on why you guys seem to want grey?
Black or transparent (no colour) makes it look much cleaner.
I wouldn’t be complaining if the grey didn’t cover up 90% of the video on screen.
@sixones
I agree. I don’t mind the grey background on it, but the gradient fade moving up the screen is unnecessary, ugly, and intrusive. Whatever you do to fix this, the background of the OSD should not extend more than necessary above the controls.
I agree with your point about it not extending past the playback controls interface but I really would prefer no tint or colour at all. The less amount of stuff covering my content, the better.
@daioio @jesusmc
The trouble with that is that the controls might be hard to read at times, depending on what’s on screen.
I’d also like the option to see the 1st couple of lines of the program description in the OSD. You then wouldn’t have to stop the video to go back and read it.
I pause and resume a lot, I like to use the OSD and the grey is ugly, no question about it.
Your argument is pretty weak here as the gradient covers nearly all of the video on screen and just looks cheap.
That’s not the point I’m making and you know it.
The UI should be clean and there was nothing wrong with the black before. It looked classy. Now it’s just bleak.
Please stop arguing points that aren’t relevant to the discussion. I would like to see some discourse between the devs and the users as to why they want to use grey over black / transparent.
The devs literally changed from grey to black the last time I asked this so yes, I do believe a discussion can be had given there was one last time I raised this is and yes, a developer responded. Please stop derailing the subject.
This is a channel for feedback, if something doesn’t fit right, this is the place to voice that feedback as I have done here.
Raising a small user experience issue does not detract from any larger design changes. All changes can be considered and I’m not taking anything away by politely requesting a change. If you’re unhappy with the design of the app I suggest to create your own thread instead of discussing it here.
Agree with everything mediahorder said and disagree with spgra…
I use chapter thumbnails i would like to think most people use chapter thumbs or at least some, and they look bad covered in gray.
