Server - 1.10.1.4561
Web - 3.55.3
Under Live TV & DVR it still says “Program Guide”
Where oh where can I find my lost guide?
Web - 3.55.3
Need to be on a Plex Media Server version that supports the new grid.
I’m on Plex Media Server 1.13.2.5154 and Plex Web 3.55.3 and it’s available, so you probably just need to update your plex server. After that click on “Guide” and make sure you select the Channels view
Looks like automatic updates aren’t working on my server then - I’m on Beta channel and “Check for Updates” button won’t work. I’ll pull latest from the website. None of the announcements mentioned the version except for one I caught that talked about the “Web” version that I was newer than.
That did it - thank you very much for clarification on minimum version requirements.
