Server Version#1.18.1.1973: Mac
Player Version#1.4 Preview Mac
I did found a bug; if you click on the play button as indicated in the screenshot, you do not get the intended HD version of the channel you get the SD version of the channel. The only way to get the HD version is to click on the actual play button on the actual show you want to watch.
There’s another half of this bug you should watch out for. If you set up a “season pass” on an HD channel you will record SD episodes instead if they air sooner or at the same time as the HD airings. You must ensure you have “prefer HD” checked globally or you’ll get sad faced when you eventually watch them and notice…
