Guide reverts to lowest channel
Server Version#:
Player Version#: 8.29.0.30433 b3774acd
Tuner Make/Model: HD homerun
Guide/Lineup name:
Using XMLTV?:
Channel number/Name:
HI all, not sure if this is me or I missed something on here, but when I tune to any channel from the guide in plex, and then back out to the guide, it goes back to the lowest channel. I then need to scan back to the channel I was on to progress to the next channel. Not sure if it was an app update or a server update that broke this? I used to hit back from a channel to the guide and I’d be at the channel I was just watching. Any ideas how to fix? I stopped the app and cleared cache and neither worked or resolved it. I am using an ONN device with Android OS.
Seeing the same behavior. I agree it should revert to the channel last selected.
Server: 1.25.5.5492
Player: 8.29.0.30300-beta
Is there a way to formally submit this as a bug?
We have a bug report for this already. I’m sorry I do not have an ETA
Is this tied back to the plex app or server? Curious if there is a way to revert back one of those until it is resolved?
from what I can tell it is app related. You can get previous versions of android app in the release notes topic
https://forums.plex.tv/t/plex-for-android/29115/last
This should be fixed on the latest beta Release Announcements - Android TV beta - #500 by marekszulik
Great, I will download it later today and give it a try
I can confirm the beta resolves the issue. I can click back and I am taken back to the guide at the channel I am on.
