Guide sorting by xml data name and not channel number
Server Version#: 1.32.4.7195
Player Version#: all
Tuner Make/Model: xteve
Guide/Lineup name: n/a
Using XMLTV?: yes
Channel number/Name: n/a
After rebuilding the server the guide is now sorting by xml data name and not channel name… For example channel 1105 which is the 8th channel in the list is populating first because guide2go.10146.schedulesdirect.org comes up first in the order within the xml data. When assigning xml data the listing is correct, when actually browsing it is in the wrong order…
all good… had to target xteve.xml created by xteve and not the separate xml that was created by guide2go… ping me if you run into a similar issue…
