Half stars became a thing a while ago but even if they can be set in the gui under the cover picture, while sorting on rating, they can not be set in edit which is needed if you would like to change multiple ratings at once.
Since ratings where only local before i used my own interpretation of what a 1 and a 2 star ment for me, a 1 star was something to be removed and a 2 star was about a 6/10 and so forth. Now with discover together your ratings become public and so it will need to be changed to a more general view of 3 star equal a 6/10 and so forth. This would make me need the use of the half star rating system which is not available in the edit prompt and hence cant be done i batches. Please fix this.
