Hardware acceleration/hardware transcoding device clarification
Seeking some clarification as I’m beginning to believe I perhaps have a misunderstanding. I have a new older computer setup as a backup plex server that has both a dedicated gpu and integrated. I have plex pass and so I have hardware acceleration enabled as well I have the dedicated card selected. However I look at the graphics card usage while play back is in direct playback, and transcoding both on network and remote. I only ever see the igpu being used which leads me to think I have a misconception of what is or should be going on.
PMS: 1.41.6.9685-d301f5-511a
OS: Win 11 Pro Build 26100.406
CPU: i5-8400H
iGPU: Intel UHD 630
NVidia MX130
Nvidia Control Panel: ver 553.46
Fresh install all showing up to date
I am sure there is some more information I can give but unsure what to provide other. Any clarification of this would be greatly appreciated. Please let me know if more information is needed. Thank you community.
Everything appears to be working ideally for your set-up.
According to this Nvidia page your GPU does not support transcoding - or at least it doesn’t use the modern Nvenc engine.
Video Encode and Decode GPU Support Matrix | NVIDIA Developer
You’re Intel iGPU appears to be what Plex had found and according to your description is working as expected - it’s handling your transcoding.
Your Intel GPU has great codec support - for Plex. (See below)
But that’s just my 2 cents - someone could likely give you a more indepth description and diagnosis.
Intel Article Link Encode and Decode Capabilities for 7th Generation Intel® Core™ Processors and Newer
Thank you, I figured the answer would be simple and I just didn’t know the correct search criteria. As well it lets me know more information about how my aging main rig also lines up… And oof :joy:
