Hardware Acceleration not working on Synology DS1019+
Current version 1.32.7.7571, on a 1019+, installed normally, works perfectly. There’s nothing special you need to do. Reinstall without docker, current version.
1
Thank you checking it in a few
Have a workaround for all GeminiLake CPUs.
We figured out the problem and what needs to be corrected.
Problem and solution space are now well defined.
Details here:
1.32.7.7571 still uses software transcoding on my DS1019+. This beta update did not fix my problem. I wish I knew what was different between your NAS and mine…
I’m confused. This is for a standard linux system. Is this applicable for my issue?
@ChameleonXtreme
For you (on Synology),
  1. Target directory is
    PlexMediaServer/AppData/PlexMediaServer/Cache/va-dri-linux-x86_64
  2. Install and use the Synology Text Editor to add the setting to Preferences.xml
Now Plex won’t load. I think it’s core dumping. Trying to locate the log for that.
PlexMediaServer/AppData/Plex Media Server
Right-Click LogsCompress to Logs.zip
I bet you have a typo in Preferences.xml
(It gets TOTALLY STUPID when there’s an error – OR – Permissions are wrong)
Preferences.xml must be owned by PlexMediaServer:PlexMediaServer
The VaapiDriver=“i965” was already in the xml, by adding it w/o looking, it just simply died due to invalid XML. I should have checked, but I assumed since I didn’t ready to check that it doesn’t already exist, that it must be a new entry.
Adding the driver worked. My system prior to the update had (and still does) iHD_drv_video.so which is a symlink to /var/packages/PlexMediaServer/shares/PlexMediaServer/AppData/Plex Media Server/Drivers/imd-115-linux-x86_64/dri/iHD_drv_video.so
I wonder if my issue was because my Preferences.xml already had the VaapiDriver entry and the driver was missing?
T H A N K   Y O U ! ! !
Now I can watch TV on my 1080p bedroom TV again.
You will indeed have iHD_drv_video.so. (Intel Media Driver)
Now you have two. IMD and i965
W E L C O M E ! ! !
:slight_smile:
You must have had things customized beyond out of the box before hand. I have never needed to do anything. Or you aren’t on a 1019+. BTW those instructions aren’t even for the 1019+, it’s apollolake.
ALL:
To be clear to everyone:
  1. The ApolloLake CPUs were fixed by a permanent code change as of 1.32.5.7210
    and do not require customization. Changing the driver is optional/
  2. The customization I provided here will work with BOTH CPU families: J3xxx and J4xxx. Both are i965-capable.
  3. For the time being. it’s a workaround until we implement the permanent code changes we need. Until today, while the problem was well known, the specifics were not well defined. Now. they are.
No, but I have been on the beta channel forever. I am a professional programmer, but I am hands-off when I end my day job, and have no interest in tinkering anymore. After 30 years, I’m burned out and just want to be a regular user.
I learned more about Plex on the Synology over this short venture than I ever cared to learn.
I’m just glad it’s working now.
Haha
