After noticing the recent HW transcoding problem, I switched to version 1.32.1.6999 as recommended and everything worked again.
Seeing the new version 1.32.4.7164, I wanted to test to see if the problem was solved. Unfortunately the problem still exists on my synology server with the processor: INTEL Celeron J3455 1.5 GHz.
You will find the logs in order to investigate in more detail. (see at Jun 06, 2023 00:44:57.346, line 2175)
Same thing here but with a terra master F4-422 with intel J3455 1.5 GHz. I had to roll back to version 1.32.1.699 to have hardware transcoding. All version after that, the hardware transcoding doesn’t work. Please fix this.
The ApolloLake fixes will be in the next PMS build/release from what I can see.
There is a fundamental change here for folks to understand.
There is an educational change needed here. The i965 driver is old and dated. It shouldn’t be used. The Intel Media Driver is the established replacement for a few years now. Please refrain from i965.
DO NOT USE VaapiDriver="i965" in Preferences.xml without first checking with first confirming the Intel Media Driver doesn’t work -and- you’ve reached out to us.
There might be an issue here and there but, if we don’t heard about them then we won’t know what needs fixing.
Bottom line – No VaapiDriver="i965" in Preferences.xml should ever be needed.
Sorry if this has been asked before… I’m using a Synology DS720+ that has the Celeron 4125 / Gemini Lake family so is it ‘ok’ to upgrade from 1.32.1.6999 or should I wait?
I was also experiencing an issue with Plex 1.32.3.7162 (docker) not leveraging hardware transcoding as I would expect.
Rolling-back to an earlier version (1.31.3.6868) resulted in hardware transcoding working.
So based on what @ChuckPa mentioned about the VaapiDriver="i965" in Preferences.xml, I removed this reference and restarted Plex against the current version (1.32.3.7162 ) and once again hardware transcoding seems to be working again.
There are only a very few CPUs which need the i965 driver.
The best first choice is to use the default Intel Media Driver due to the recent major upgrade of the media driver released a few versions ago. (1.32.0)
Some CPUs will need the upcoming ApolloLake correction but will then run without the i965 being manually selected.
