Hardware Transcoding Fails Only for 4K on TruNAS (Worked on Ubuntu)
Server Version#:1.42.2.10156
I’ve recently upgraded, on the exact same hardware from Ubuntu 24.04 (Bare metal install) to TruNAS Community (Container).
Alder Lake CPU (12th gen) with Quicksync, no GPU
My versions of Plex on both are/were version 1.42.2.10156, and I’m a Plex Pass holder.
I did a clean install in TruNAS as an App/Docker, and copied over the database and config files to not lose my Collections and all that. The paths are nearly the same.
Playback using direct play works fine in all instances, my collections and custom art, etc.. is all there.
The problem is…. Hardware transcoding (hw) worked flawlessly on the Ubuntu install from 4K (with or without HDR) to 720p, and now on the TruNAS install, 4K HDR to 720p, the hardware transcoding doesn’t kick in (uses all kinds of CPU). BUT, going from a 1080p to 720p file, the hardware transcoding kicks in and works as it should.
In the console (Warning and Error enabled)…I get these errors…
Nov 22, 2025 19:24:17.445 [140261852474168] Error — [Req#4607/Transcode/8fea2754-778a-4740-9130-4b8ce9334071/ea38f5b7-7f77-4b11-9092-3bbe2377f86c] [AVHWDeviceContext @ 0x7fb722cbc040] No matching devices found.
Nov 22, 2025 19:24:17.448 [140261852474168] Error — [Req#461e/Transcode/8fea2754-778a-4740-9130-4b8ce9334071/ea38f5b7-7f77-4b11-9092-3bbe2377f86c] [Parsed_tonemap_opencl_3 @ 0x7fb7263795c0] Failed to build program: -6.
Nov 22, 2025 19:24:17.448 [140261852474168] Error — [Req#4620/Transcode/8fea2754-778a-4740-9130-4b8ce9334071/ea38f5b7-7f77-4b11-9092-3bbe2377f86c] Error while filtering: I/O error
Nov 22, 2025 19:24:17.449 [140261852474168] Error — [Req#4623/Transcode/8fea2754-778a-4740-9130-4b8ce9334071/ea38f5b7-7f77-4b11-9092-3bbe2377f86c] Failed to inject frame into filter network: I/O error
Nov 22, 2025 19:24:17.449 [140261852474168] Error — [Req#4627/Transcode/8fea2754-778a-4740-9130-4b8ce9334071/ea38f5b7-7f77-4b11-9092-3bbe2377f86c] Error while processing the decoded data for stream #0:0
I’ve searched this forum with no real luck of finding a solution.
If I disable HDR tone mapping, it kicks in hardware transcoding the way it should. But it used to work with my old setup with that enabled.
If anyone can offer some insight that would be great.
I’m experiencing the same error, with an Intel N150 (Alder Lake-N) igpu. Also on v1.42.2.10156
Attached some logs with more context preceding the snippet above
transcode-hdr-tonemapping-debug.txt (69.4 KB)
