I have Hardware Transcoding Selected in advanced settings, but it appears to work randomly, some of my 4K Movies stream to my devices and others don’t.
Watching the Task Manager on the windows machine that runs the server, sometimes it uses the GPU and everything is fine, others times, it 100% CPU transcoding that crushed the server..
The log file on your screenshot is not included in the zip file. The rest of them doesn’t contain any hints about the playback events.
Please include the full zip file
Yes, the HD 630 officially supports 10 bit color depth and HEVC.
Did you perform the playback test with disabled subtitles?
Do you have several GPUs in this machine? (e.g. one in the GPU and one in a separate graphics adapter)
Sometimes the embedded GPU is disabled when a separatze graphics adapter is added. This is usually determined in the BIOS settings.
Did you install the latest Intel graphics driver? Sometimes Windows only installs generic driver software which doesn’t activate all features of the hardware (particularly after major Windows Updates).
The Server’s Intel Graphics Driver was downlevel, I updated it to current.
I checked, Subtitles where on, I disabled them, and re-ran the test. No, (HW) in the “Now Playing” but nothing ever played on the device, just a spinning circle. but this time, it said “Direct Stream” but converting to MP4?
Yes, but we are trying to test the transcoder here, so we must of course provoke transcoding. And that is most easily done by restricting the target bitrate.
You could conduct another test:
Take any SRT file you can get your hands on and place it beside the movie file.
(identical filename, except the filename extension)
Afterwards, select this subtitle instead of one of the PGS subtitles.
Repeat the playback test.
