Server Version#: 1.13 (latest as of Oct 2)
Player Version#: Latest in firefox
So I found out today that one of the perks of my plex pass is letting my cpu transcode prettier videos, after all, why not, it is a top of the line CPU. 8th gen, i7, 8086k (better than 8700k) 5ghz.
So I tried to transcode a 4k remux video 10bit, and I didn’t get the (HW) next to the info meaning the transcode didn’t work. Tried a few, same situation.
So I tried to transcode 1080p down, see if it worked, and same thing, didn’t work.
Then I googled and came across these 3 links:
Turns out I need subtitles off for HW transcoding to work??? Dumb in 2018 but ok, disabled subtitles. 4k still didn’t work. Might be due to the 10bit color cammut in the 4k HDR?
Went back to 1080p video, and BEHOLD it works… (I can see the HW next to it) – except the problem is the video is INSANELY CHOPPY!!! I told it to transcode to 10mbps, and its stuttering every 3-4 seconds, its like missing frames and its blatantly evident.
I tinkered with the settings under transcoder, changed the throttle from 60 to 90 to 120 to 30, no luck.
Changed quality to: Auto, high speed, high quality, and make cpu hurt, didn’t matter - still choppy. Changed background transcoding from very fast to slower to faster to fast, back to very fast. Didn’t work.
Only thing that gives me smooth playback is disabling the checkbox that enables HW acceleration to begin with.
What gives???
Thing is: my UL speed is limited to 35mbps, so if I share my 4k library, my 8086k dies (apparently without HW encoding, transcoding 1 4k video with 80mbps source down to 10-20mbps) = 65% of my cpu power being used. So basically, if 2 people try to transcode 4k videos = game over.
Am I doing something wrong?
Other specs: 16GB 3000mhz DDR4 ram.
Discreet GPU: r9 280 from 2014 (old gaming card I no longer use)
Help!
