Server Version#: DSM 7.2-64570 Update 1, DVA3221 with GTX 1080 Ti installed.
Player Version#: 1.29.2.6364 (Synology default insatall version)
Dear,
I want to report about the hardware transcording is not working properly on my server. (I have Plex Pass subscription)
First of all, the hardware transcording(GPU) works for maximum 2 contents at the same time. And newer update than the current version(1.29.2.6364) including 1.32.5.7349, 1.32.6.7371 doesn’t work at all.
So I can’t update to new version while i tried to update and test every versions so far, but it gets worse (The GPU is not working during the transcording, but only CPU is working).
I wish this problem could be solved as soon as possible since i could not update for the later version, nor to imporve the server system.
Thanks.
Please confirm what you are asking?
You want either :
- which version of Plex works on DSM 7 with the DVA3221 and Nvidia GPU ?
-or-
- to know which Synology NAS will work with Hardware transcoding ?
I’m having difficulty understanding what you’re asking for because I don’t know what you previously had which worked.
I am the Synology support engineer at Plex. I wrote all the new DSM 7 support package.
I also support QNAP NAS systems and Linux hosts.
If I know what you previously were using successfully, then I can understand better what is actually missing because I’ve never supported Nvidia on Synology (DSM 6)
You never read my post in detail.
Player Version#: 1.29.2.6364 (Synology default install version)
1.29.2.6364 version is working now, but it has a limit of 2 contents at the same time.
Synology DVA3221 include Nvidia’s GTX 1050 graphic card as a factory setting
and Nvidia’s Driver included in DSM too.
So it supports GPU by DSM as a default, but Plex’s HW transcoding not working properly,
Nvidia transcoding limits are limited by the driver, not PMS.
I have a P2200 which is unlimited because of the type card it is.
I am going to say again, an I’m sorry:
- No Synology DVA models have been submitted to Plex for testing and inclusion on the NAS Compatibility List.
Because I’ve not seen / worked on a DVA model NAS, I have not written in the installer to support them. We have DS model NAS systems in our lab.
Without having access to a DVA series NAS, I don’t know how it is structured in DSM. Without that knowledge, I cannot adjust the PMS installer to support it.
I am sorry but you’re using PMS on an unsupported Synology product.
You ask where I am. I am in eastern United States.
Okay, to supporting Synology DVA Series is your choice.
- Nvidia transcoding limits are limited by the driver, not PMS.
No, mine works unlimited too when I run PMS on the windows 10,11.
It has a limit on Synology PMS only.
If the transcoding doesn’t get limited by PMS, why every update versions later than 1.29.2.6364 are working differently? I presume it’s affected by PMS.
Since PMS has an option for hardware transcording support (Plex Pass), GPU HW transcoding issue is caused by PMS not Nvidia driver.
