Harmony Setup
so i try around with a remote for the Pi, at last it dont work for me here is what i done:
Setup a new Device "Mediacenter Pc" Factory "Plex" "Plex Player", click click enter -> renamed it done.
So this dont work for the Pi anyone a idea?
I used the Android app, found here, everything worked right away except the back button. I will plug my harmony remote in today and try it.
Are you using IR or CEC?
If CEC, then you dont even need to set the Pi as a device you just use your TV controls.
