has anyone got rasplex working on noobs?
hi,
I have a Raspberry Pi 2 and a SD-card of 8GB.
Noobs is installed on the SD-Card with RASPBIAN and OPENELEC.
I’d like to add rasplex to this OS-es, but I didn’t manage to get it working.
I tried copying the img-file of rasplex to the ‘OS’ folder on the recovery partition, but there isn’t enough space for that.
Any Ideas?
Thanks in advance!
Search this section you will find numerous topics covering this, Noobs is basically Berryboot, dlanor has listed numerous how-to for this.
Regards
Regards
Well I have been looking through his posts and discussions, but I haven’t found a tutorial for this. Could be I missed it, but have been looking for a while now.
I’ve found a dualboot of rasplex with retropie on the net and managed to change that config to rasplex with rasbian. updating rasplex on from 0.7 to 1.0 manually brought me where I wanted to be.
nevertheless, The issue isn’t solved yet, because other might experience the same issues. If I’d like to reinstall it in the future, I would have to use this workaround again…
A 2 second search brought this up https://forums.plex.tv/discussion/comment/902297#Comment_902297
I must have missed that thread… strange, but this is indeed what I was looking for!
apologies for not finding out myself!
Thanks for helping me out!
Glad you’re good to go.
Regards
