How do you get Plex to see and use all 4 tuners on the Hauppauge quad HD, I’m only able too use two of the 4 tuners?
Hi - the 4 tuners on that card (I have one also) are actually 2 sets of 2 tuners on the same card. Therefore you when you first setup the device, it only picks up 2 tuners. You need to go though that process again (I believe you click Add Device) to add the second bank of 2 tuners and scan channels, setup the channels, etc. The one card essentially looks like two devices. That’s because of how the card is setup and nothing to do with Plex.
Hope this helps!
Thanks for information, when I first installed Tuner card, Plex did fine and did show 2 PCIe found, I could only pick one of the two listed to be installed and did that, then went back to DVR setup to install the 2nd one, but now Plex no longer has the 2nd one showing for me to install. with the 2nd tuner device not listed on my Plex DVR setup, I’m asked to enter the network address manually, any chance you know how to do that?
Make sure both cards show up in device manager on windows, uninstall any tv software you may have installed that came with it such as WinTV. You only need the windows drivers loaded, and get the latest available.
http://hauppauge.com/pages/support/support_quadhd.html
Thanks jmfolcik , with your help I am now able to use all 4 tuners on my Plex!! it worked!!
