Hello I have one of the Hauppauge WinTV-dualHD TV Tuner which is for ever just dropping off from PLEX in the Live TV & DVR section under the server is for ever saying device not found yep it will show up in device manager and if I install the Hauppauge tuner software it will work fine with that software yet PLEX cant see it I have to delete DVR delete and re setup and it will go ok for a little while and them same issues again the PC is set to never sleep running Win7 all updates are applied have made sure the power management for the USB ports is turned off just at a loss thinking I should of brought one of the HDHomeRun any help much appreciated.
I’m new and trying to set up PLEX Live TV on my WD PR2100 NAS. Shows only HomeRun option and buffers continuously until I cancel. Has this problem been addressed? Is there a solution? If so how do I get it. Thanks in advance for any help.
