I have it where iBaa theme is working but CyberGhost84 will not pull up ,my Plex Server…
Here are the log errors…
02:07:05 PlexAPI: No Response from Plex Media Server
02:07:05 PlexAPI: We failed to reach a server. Reason: Unauthorized
02:07:05 PlexAPI: Traceback:
Traceback (most recent call last):
File “/Applications/PlexConnect/PlexAPI.py”, line 406, in getXMLFromPMS
response = urllib2.urlopen(request, timeout=20)
File “/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/urllib2.py”, line 154, in urlopen
return opener.open(url, data, timeout)
File “/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/urllib2.py”, line 437, in open
response = meth(req, response)
File “/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/urllib2.py”, line 550, in http_response
‘http’, request, response, code, msg, hdrs)
File “/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/urllib2.py”, line 475, in error
return self._call_chain(*args)
File “/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/urllib2.py”, line 409, in _call_chain
result = func(*args)
File “/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/urllib2.py”, line 558, in http_error_default
raise HTTPError(req.get_full_url(), code, msg, hdrs, fp)
HTTPError: HTTP Error 401: Unauthorized
Any ideas why one theme would work and the other will not?
