plex connect says unauthorised
Apple TV model 3 version 7.0.1
DNS - 192.168.1.3
Local address - 192.168.1.3
Windows 10
Plex server version 1.3.3.3148
Plex local - 192.168.1.3
Downloaded copy today of plex connect
Have an issue where plex connects say unauthorised and on the trailers screen its says plex connect no plex libraries sections available. If i go across to the settings tab it has found my server.
here is the log
10:42:13 PlexConnect: started: 10:42:13
10:42:13 PlexConnect: Version: 0.5-dev-110616
10:42:13 PlexConnect: Python: 2.7.13 (v2.7.13:a06454b1afa1, Dec 17 2016, 20:42:59) [MSC v.1500 32 bit (Intel)]
10:42:13 PlexConnect: Host OS: win32
10:42:13 PlexConnect: PILBackgrounds: Is PIL installed? False
10:42:13 PlexConnect: IP_self: 192.168.1.3
10:42:14 DNSServer: started: 10:42:14
10:42:14 DNSServer: ***
10:42:14 DNSServer: DNSServer: Serving DNS on 192.168.1.3 port 53.
10:42:14 WebServer: started: 10:42:14
10:42:14 WebServer: ***
10:42:14 WebServer: WebServer: Serving HTTP on 192.168.1.3 port 80.
10:42:14 WebServer: WebServer: Serving HTTPS on 192.168.1.3 port 443.
10:42:20 PlexAPI: ***
10:42:20 PlexAPI: PlexGDM - looking up Plex Media Server
10:42:21 PlexAPI: GDM: Servers discovered: 1
10:42:21 PlexAPI: Servers (local, plex.tv, MyPlex): 2
10:42:21 PlexAPI: No Response from Plex Media Server
10:42:21 PlexAPI: We failed to reach a server. Reason: Unauthorized
10:42:21 PlexAPI: Traceback:
Traceback (most recent call last):
File “C:\Program Files\PlexConnect-master\PlexAPI.py”, line 432, in getXMLFromPMS
response = urllib2.urlopen(request, timeout=20)
File “C:\Python27\lib\urllib2.py”, line 154, in urlopen
return opener.open(url, data, timeout)
File “C:\Python27\lib\urllib2.py”, line 435, in open
response = meth(req, response)
File “C:\Python27\lib\urllib2.py”, line 548, in http_response
‘http’, request, response, code, msg, hdrs)
File “C:\Python27\lib\urllib2.py”, line 473, in error
return self._call_chain(*args)
File “C:\Python27\lib\urllib2.py”, line 407, in _call_chain
result = func(*args)
File “C:\Python27\lib\urllib2.py”, line 556, in http_error_default
raise HTTPError(req.get_full_url(), code, msg, hdrs, fp)
HTTPError: HTTP Error 401: Unauthorized
10:42:50 PlexAPI: ***
10:42:50 PlexAPI: PlexGDM - looking up Plex Media Server
10:42:51 PlexAPI: GDM: Servers discovered: 1
10:42:51 PlexAPI: Servers (local, plex.tv, MyPlex): 2
10:49:04 PlexAPI: ***
10:49:04 PlexAPI: PlexGDM - looking up Plex Media Server
10:49:05 PlexAPI: GDM: Servers discovered: 1
10:49:05 PlexAPI: Servers (local, plex.tv, MyPlex): 2
10:49:05 PlexAPI: No Response from Plex Media Server
10:49:05 PlexAPI: We failed to reach a server. Reason: Unauthorized
10:49:05 PlexAPI: Traceback:
10:59:26 PlexAPI: ***
10:59:26 PlexAPI: PlexGDM - looking up Plex Media Server
10:59:27 PlexAPI: GDM: Servers discovered: 1
10:59:27 PlexAPI: Servers (local, plex.tv, MyPlex): 2
10:59:28 PlexAPI: No Response from Plex Media Server
10:59:28 PlexAPI: We failed to reach a server. Reason: Unauthorized
10:59:28 PlexAPI: Traceback:
11:00:47 PlexAPI: ***
11:00:47 PlexAPI: PlexGDM - looking up Plex Media Server
11:00:48 PlexAPI: GDM: Servers discovered: 1
11:00:48 PlexAPI: Servers (local, plex.tv, MyPlex): 2
11:00:49 PlexAPI: No Response from Plex Media Server
11:00:49 PlexAPI: We failed to reach a server. Reason: Unauthorized
11:00:49 PlexAPI: Traceback:
11:01:31 PlexAPI: ***
11:01:31 PlexAPI: PlexGDM - looking up Plex Media Server
11:01:32 PlexAPI: GDM: Servers discovered: 1
11:01:32 PlexAPI: Servers (local, plex.tv, MyPlex): 2
11:01:33 PlexAPI: No Response from Plex Media Server
11:01:33 PlexAPI: We failed to reach a server. Reason: Unauthorized
11:01:33 PlexAPI: Traceback:
11:01:57 PlexConnect: Shutting down.
11:01:58 WebServer: Shutting down (HTTPS).
11:01:58 WebServer: Shutting down (HTTP).
11:02:00 DNSServer: Shutting down.
11:02:00 PlexConnect: shutdown
PMS implemented a new security mechanism. You need to take one of these actions:
  1. Log in PMS and PlexConnect to the same myplex userid
  2. Use PMS advanced settings to allow unauthorized access requests from the LAN
