SERVER
Server Version#:1.40.2.8395-c67dce28e (hotio unraid plex repository)
OS Version: Linux 6.1.79-Unraid
LG WEB OS
Client Version#: 5.83.1
Platform Version: 5.5.0
Hi all,
I recently upgraded my server from windows to unraid and so far have had no issues. I installed tailscale vpn and and ssl certbot from this github repository (GitHub - kchristensen/udm-le: Let's Encrypt support for Ubiquiti UniFi OS) on my UDM-pro and since then have had issues with direct play from my plex server.
As you can see from the screenshots, the connection is fine for some of the devices on my local network, however others are having issues with direct play (getting indirect connection from my LG CX65 for example).
I can also upload a screenshot of my firewall rules if needed. But I currently have the following firewalls set up:
Allow Plex Remote Traffic (internet in)
TCP
Source: Any
Port: Any
Destination: Server IP (192.168.1.231)
Port: Plex Port (32400)
Allow Plex Local (internet Local)
TCP
Source: Private IPs (192.168.1.0/24)
Port: Any
Allow Local Plex Traffic (LAN In)
TCP
Port: Any
Allow Local Plex Traffic (LAN Out)
TCP
Source: Server IP (192.168.1.231)
Port: 32400
Destination: Private IPs (192.168.1.0/24)
Port: Any
Here are the logs as well:
plex logs 06032024.zip (3.2 MB)
