I have set them up as an ‘Other videos’ library but even though I have the year in each video’s filename (Artist - Title (2017)), Plex just puts 2019 for them all. It’s a shame.
if you followed the section @ “Global Music Videos Folder” in your above link, you should find the music videos under the applicable ARTIST in the Music library.
unfortunately there is not a music video library that is separate from the music library.
Music Videos are essentially considered a different type of music file that is kept with audio files (or audio library).
I have not tried, but you may able to create some ‘smart’ playlists using filters that will make it easier to find the music videos.
I followed the section @ “Global Music Videos Folder” in above link, but could not find any music videos under the applicable ARTIST in the Music library.
Thanks. That is indeed the trick is. The content of the global music video folder is only recognized after Refreshing Metadata of the music library or the artist.
