Server Version#: 4.76.1
Player Version#: Web Chrome Edge and Also 1.45.0.3013-1676042f
Tuner Make/Model: HDHome Run Quad
Guide/Lineup name: Freeview (154 channels)
Using XMLTV?: No
Channel number/Name: All
I have tried a brand new install and I still get the same issue and also tried to install on another server pointing to the HDHomeRun IP with the same results.
I am getting alot of these errors
MANAGE
WestWinds-PLEX—Plex Media Server Logs
AllRAW
May 31, 2022 10:38:17.727[13432]SQLITE3:0xdda778e0, 1, statement aborts at 1: [COMMIT] cannot commit - no transaction is active
May 31, 2022 10:38:17.727[13432]Failed to commit transaction (E:\jenkins\server\3581022487\Library\MetadataItemClustering.cpp:114) (tries=4): Cannot commit transaction. cannot commit - no transaction is active
May 31, 2022 10:38:17.978[13432]SQLITE3:0xdda778e0, 1, statement aborts at 1: [COMMIT] cannot commit - no transaction is active
May 31, 2022 10:38:17.978[13432]Failed to commit transaction (E:\jenkins\server\3581022487\Library\MetadataItemClustering.cpp:114) (tries=5): Cannot commit transaction. cannot commit - no transaction is active
May 31, 2022 10:38:18.229[13432]SQLITE3:0xdda778e0, 1, statement aborts at 1: [COMMIT] cannot commit - no transaction is active
May 31, 2022 10:38:18.229[13432]Failed to commit transaction (E:\jenkins\server\3581022487\Library\MetadataItemClustering.cpp:114) (tries=6): Cannot commit transaction. cannot commit - no transaction is active
May 31, 2022 10:38:18.480[13432]SQLITE3:0xdda778e0, 1, statement aborts at 1: [COMMIT] cannot commit - no transaction is active
May 31, 2022 10:38:18.480[13432]Failed to commit transaction (E:\jenkins\server\3581022487\Library\MetadataItemClustering.cpp:114) (tries=7): Cannot commit transaction. cannot commit - no transaction is active
May 31, 2022 10:38:18.732[13432]SQLITE3:0xdda778e0, 1, statement aborts at 1: [COMMIT] cannot commit - no transaction is active
May 31, 2022 10:38:18.732[13432]Failed to commit transaction (E:\jenkins\server\3581022487\Library\MetadataItemClustering.cpp:114) (tries=8): Cannot commit transaction. cannot commit - no transaction is active
May 31, 2022 10:38:18.983[13432]SQLITE3:0xdda778e0, 1, statement aborts at 1: [COMMIT] cannot commit - no transaction is active
May 31, 2022 10:38:18.983[13432]Failed to commit transaction (E:\jenkins\server\3581022487\Library\MetadataItemClustering.cpp:114) (tries=9): Cannot commit transaction. cannot commit - no transaction is active
May 31, 2022 10:38:19.234[13432]SQLITE3:0xdda778e0, 1, statement aborts at 1: [COMMIT] cannot commit - no transaction is active
May 31, 2022 10:38:19.234[13432]Failed to commit transaction (E:\jenkins\server\3581022487\Library\MetadataItemClustering.cpp:114) (tries=10): Cannot commit transaction. cannot commit - no transaction is active
May 31, 2022 10:38:19.234[13432]Exception inside transaction (inside=1) (E:\jenkins\server\3581022487\Library\MetadataItemClustering.cpp:114): Cannot commit transaction. cannot commit - no transaction is active
May 31, 2022 10:38:19.234[13432]SQLITE3:0xdda778e0, 1, statement aborts at 1: [ROLLBACK] cannot rollback - no transaction is active
May 31, 2022 10:38:19.234[13432]Failed to roll back transaction (E:\jenkins\server\3581022487\Library\MetadataItemClustering.cpp:69): Cannot rollback transaction. cannot rollback - no transaction is active
May 31, 2022 10:38:19.234[13432]Thread: Uncaught exception running async task which was spawned by thread 10940: Cannot commit transaction. cannot commit - no transaction is active
May 31, 2022 10:38:19.259[13432]Updating metadata item (save) (AR_EFFECT_20140823154831) with ID 101337
May 31, 2022 10:38:19.260[13432]Failed to commit transaction (E:\jenkins\server\3581022487\Library\MetadataItemClustering.cpp:114) (tries=1): Cannot commit transaction. database disk image is malformed
May 31, 2022 10:38:19.511[13432]SQLITE3:0xdda778e0, 1, statement aborts at 1: [COMMIT] cannot commit - no transaction is active
May 31, 2022 10:38:19.511[13432]Failed to commit transaction (E:\jenkins\server\3581022487\Library\MetadataItemClustering.cpp:114) (tries=2): Cannot commit transaction. cannot commit - no transaction is active
May 31, 2022 10:38:19.762[13432]SQLITE3:0xdda778e0, 1, statement aborts at 1: [COMMIT] cannot commit - no transaction is active
May 31, 2022 10:38:19.762[13432]Failed to commit transaction (E:\jenkins\server\3581022487\Library\MetadataItemClustering.cpp:114) (tries=3): Cannot commit transaction. cannot commit - no transaction is active
May 31, 2022 10:38:20.013[13432]SQLITE3:0xdda778e0, 1, statement aborts at 1: [COMMIT] cannot commit - no transaction is active
May 31, 2022 10:38:16.951[13696]LPE: unknown item 69453.
May 31, 2022 10:38:16.951[13696]Sync: failed to generate query for path library://01db49bf-fc1c-48b0-96df-ff62971c3ebf/item/%2Flibrary%2Fmetadata%2F69453 in sync item 48697923
May 31, 2022 10:38:16.951[13696]Sync: sync item 48697923 has an empty sync set query, assuming sync item is no longer valid
May 31, 2022 10:38:16.951[13696]LPE: unknown item 57616.
May 31, 2022 10:38:16.951[13696]Sync: failed to generate query for path library://01db49bf-fc1c-48b0-96df-ff62971c3ebf/item/%2Flibrary%2Fmetadata%2F57616 in sync item 48697943
May 31, 2022 10:38:16.951[13696]Sync: sync item 48697943 has an empty sync set query, assuming sync item is no longer valid
May 31, 2022 10:38:16.951[13696]LPE: unknown item 57615.
May 31, 2022 10:38:16.951[13696]Sync: failed to generate query for path library://01db49bf-fc1c-48b0-96df-ff62971c3ebf/item/%2Flibrary%2Fmetadata%2F57615 in sync item 48697945
May 31, 2022 10:38:16.951[13696]Sync: sync item 48697945 has an empty sync set query, assuming sync item is no longer valid
May 31, 2022 10:38:16.951[13696]Sync: garbage collected database for sync list 62798089 in 0.0 seconds
May 31, 2022 10:38:16.951[13696]Sync: finished Sync garbage collection: 1
May 31, 2022 10:38:16.951[13696]BPQ: garbageCollect - version - forced - -1
May 31, 2022 10:38:16.951[13696]Versions: garbage collecting
May 31, 2022 10:38:16.952[13696]Versions: garbage collected in 0.0 seconds
May 31, 2022 10:38:16.974[13432]Updating metadata item (save) (AR_EFFECT_20140823154831-edited) with ID 100313
May 31, 2022 10:38:16.975[13432]Failed to commit transaction (E:\jenkins\server\3581022487\Library\MetadataItemClustering.cpp:114) (tries=1): Cannot commit transaction. database disk image is malformed
May 31, 2022 10:38:17.225[13432]SQLITE3:0xdda778e0, 1, statement aborts at 1: [COMMIT] cannot commit - no transaction is active
May 31, 2022 10:38:17.225[13432]Failed to commit transaction (E:\jenkins\server\3581022487\Library\MetadataItemClustering.cpp:114) (tries=2): Cannot commit transaction. cannot commit - no transaction is active
May 31, 2022 10:38:17.476[13432]SQLITE3:0xdda778e0, 1, statement aborts at 1: [COMMIT] cannot commit - no transaction is active
May 31, 2022 10:38:17.476[13432]Failed to commit transaction (E:\jenkins\server\3581022487\Library\MetadataItemClustering.cpp:114) (tries=3): Cannot commit transaction. cannot commit - no transaction is active
May 31, 2022 10:39:22.834 [9364] Verbose — [Transcode] It took 0.0 sec to serialize a list with 0 elements.
May 31, 2022 10:39:22.834 [10880] Debug — Completed: [127.0.0.1:59062] 206 PUT /video/:/transcode/session/f5d36cc4-27bc-40cc-be05-5ee195552cfb/6285712c-9c5c-4f5f-ab94-3f4f152e6fb5/progress?progress=-1.0&size=-22&remaining=-1&speed=6.3 (19 live) 0ms 355 bytes (pipelined: 13) (range: bytes=0-)
May 31, 2022 10:39:22.967 [13432] Error — SQLITE3:0xdda778e0, 1, statement aborts at 1: [COMMIT] cannot commit - no transaction is active
May 31, 2022 10:39:22.967 [13432] Error — Failed to commit transaction (E:\jenkins\server\3581022487\Library\MetadataItemClustering.cpp:114) (tries=9): Cannot commit transaction. cannot commit - no transaction is active
