Plex Server no longer tunes live TV channels using HDHomeRun
Server Version#: 1.31.0.6654
Player Version#: 1.62.2.3451-fb8ac0ae
Tuner Make/Model: SiliconDust HDHomeRun PRIME HDHR3-CC with firmware 20221205
Guide/Lineup name: Xfinity Digital
Using XMLTV?: No
Channel number/Name: All channels
Plex will no longer play a live TV stream from my HDHomeRun device. It had been working prior to a few Plex Server version updates ago. I can tune and view channels using the HDHomeRun Windows application and with Jellyfin’s web interface and mobile app without any issues. The following error is displayed when trying to tune any channel from the Plex Windows client or from the web interface:
Plex Media Server Logs_2023-02-01_16-11-52.zip (1.0 MB)
I see a couple of issues in your logs that need to be addressed. The first is that you have a database corruption. There are a lot of database corruption errors in your logs, and all bets of off on what is going to work until the corruption is fixed. The following is a small excerpt:
Feb 01, 2023 11:43:53.863 [0x809668500] ERROR - SQLITE3:0x10, 11, database corruption at line 66843 of [1b256d97b5]
Feb 01, 2023 11:43:53.863 [0x809667700] ERROR - SQLITE3:0x10, 11, database corruption at line 66843 of [1b256d97b5]
Feb 01, 2023 11:43:53.863 [0x809668500] ERROR - SQLITE3:0x10, 11, database corruption at line 66993 of [1b256d97b5]
Feb 01, 2023 11:43:53.863 [0x809667700] ERROR - SQLITE3:0x10, 11, database corruption at line 66993 of [1b256d97b5]
You can try a repair, or restore from a backup.
You may also have a permissions problem with your transcoder mountpoint. Typically /mnt is used for network mountpoints (e.g. not local disk.) Is this your case? If so, know that Plex recommends that your transcoder directory is NOT a network share.
Feb 01, 2023 15:27:35.329 [0x809669a00] ERROR - Transcoder: Failed to delete session directory (boost::filesystem::remove: Permission denied: "/mnt/Transcode/Sessions/plex-transcode-f041359a-ba41-4471-b44c-96f7587bf97d/media-00029.ts")
Feb 01, 2023 15:27:35.329 [0x80a956500] ERROR - Transcoder: Failed to delete session directory (boost::filesystem::remove: Permission denied: "/mnt/Transcode/Sessions/plex-transcode-f041359a-ba41-4471-b44c-96f7587bf97d/media-00029.ts")
