Server Version#: 1.30.1.2115-81e1fc3f
So I installed a new TV tuner card, hoping it would be great and reliable, as it’s designed for use with Plex. The one in question is the WinTV-quadHD. Looking at the log for the Plex Tuner Service, i get this:
Apr 12, 2021 22:05:01.807 [2636] INFO - [I] web_service_t::process_device_status
Apr 12, 2021 22:05:01.810 [32748] INFO - [I] DeviceGetListEx_impl: Filter [Hauppauge WinTV 885 ATSC Tuner/Demod 2]
Apr 12, 2021 22:05:01.810 [32748] INFO - [I] DeviceGetListEx_impl: device instance path pci#ven_14f1&dev_8880&subsys_6a180070&rev_04#6&edf7b30&0&000800e4#
Apr 12, 2021 22:05:01.810 [32748] INFO - [I] DeviceGetListEx_impl: Filter [Hauppauge WinTV 885 ATSC Tuner/Demod]
Apr 12, 2021 22:05:01.811 [32748] INFO - [I] DeviceGetListEx_impl: Filter [Hauppauge WinTV 885 ATSC Tuner/Demod]
Apr 12, 2021 22:05:01.811 [32748] INFO - [I] DeviceGetListEx_impl: device instance path pci#ven_14f1&dev_8880&subsys_6b180070&rev_04#6&326eda8f&0&001000e4#
Apr 12, 2021 22:05:01.811 [32748] INFO - [I] DeviceGetListEx_impl: Filter [Hauppauge WinTV 885 ATSC Tuner/Demod 2]
Apr 12, 2021 22:05:01.811 [32748] INFO - [I] DeviceGetListEx_impl: pDL->Count:4
Apr 12, 2021 22:05:01.811 [2636] WARN - [E] web_service_t::get_device_status. get_device_info returned error for device dvb#bda#0#@device:pnp:\\?\usb#vid_0438&pid_b003#6&21647866&0&1#{71985f48-1ca1-11d3-9cc8-00c04f7971e0}\{eec5a519-643f-4a74-bc7f-5ce7d46fefd5}
. . . and it’s repeated a lot. To try to narrow down the problem, I installed WinTV, and it sees the tuner and plays TV just fine. But I really want to use Plex, I also use it for music, and it’s more functional and friendly than WinTV.
Here is more info from the beginning of the log file:
Apr 12, 2021 22:03:35.680 [26508] INFO - Plex Tuner Service v1.0.0.0 - Microsoft PC x64 - build:
Apr 12, 2021 22:03:35.680 [26508] INFO - Windows version: 6.2 (Build 9200), language en-US
Apr 12, 2021 22:03:35.680 [26508] INFO - 16 3600 MHz processor(s): Architecture=0, Level=6, Revision=42753 Processor Identifier=Intel64 Family 6 Model 167 Stepping 1, GenuineIntel
Apr 12, 2021 22:03:35.680 [26508] DEBUG - "F:\Plex Server\Plex Tuner Service.exe" "F:\Plex Server\Resources\Tuner\Private" "F:\Plex Server\Resources\Tuner\Shared" 1.22.2.4282-a97b03fad 32600
Apr 12, 2021 22:03:35.678 [16192] INFO - [I] broker_t::start...
Apr 12, 2021 22:03:35.684 [16192] INFO - [I] device_manager_t::init.
Apr 12, 2021 22:03:35.684 [16192] INFO - [I] device_manager_t::init. Initialize provider manager
Apr 12, 2021 22:03:35.684 [16192] INFO - [I] device_manager_t::init. Initialize all device auxes
Apr 12, 2021 22:03:35.684 [16192] INFO - [I] dvb_device_factory_t::get_aux_list
Apr 12, 2021 22:03:35.684 [16192] INFO - [I] bda_aux_t::init
Apr 12, 2021 22:03:35.687 [16192] INFO - [I] web_server_t::start. Starting web server on port 32600
Apr 12, 2021 22:03:42.318 [34664] INFO - [I] web_service_t::process_device_discovery
Apr 12, 2021 22:03:42.318 [34664] INFO - [I] device_reactor_t::get_device_list ()
Apr 12, 2021 22:03:42.318 [34664] INFO - [I] dvb_device_factory_t::get_device_list ()
Apr 12, 2021 22:03:44.379 [34664] INFO - [I] SAT2IP - discover_satip_servers(): no servers found
Apr 12, 2021 22:03:44.818 [26416] INFO - [I] DeviceGetListEx_impl: Filter [Hauppauge WinTV 885 ATSC Tuner/Demod 2]
Apr 12, 2021 22:03:44.818 [26416] INFO - [I] DeviceGetListEx_impl: device instance path pci#ven_14f1&dev_8880&subsys_6a180070&rev_04#6&edf7b30&0&000800e4#
Apr 12, 2021 22:03:44.818 [26416] INFO - [I] DeviceGetListEx_impl: Filter [Hauppauge WinTV 885 ATSC Tuner/Demod]
Apr 12, 2021 22:03:44.818 [26416] INFO - [I] DeviceGetListEx_impl: device instance path pci#ven_14f1&dev_8880&subsys_6b180070&rev_04#6&326eda8f&0&001000e4#
Apr 12, 2021 22:03:44.818 [26416] INFO - [I] DeviceGetListEx_impl: pDL->Count:4
Apr 12, 2021 22:03:44.822 [34728] INFO - [I] DeviceGetListEx_impl: Filter [Hauppauge WinTV 885 ATSC Tuner/Demod 2]
Apr 12, 2021 22:03:44.822 [34728] INFO - [I] DeviceGetListEx_impl: device instance path pci#ven_14f1&dev_8880&subsys_6a180070&rev_04#6&edf7b30&0&000800e4#
Apr 12, 2021 22:03:44.822 [34728] INFO - [I] DeviceGetListEx_impl: Filter [Hauppauge WinTV 885 ATSC Tuner/Demod]
Apr 12, 2021 22:03:44.822 [34728] INFO - [I] DeviceGetListEx_impl: device instance path pci#ven_14f1&dev_8880&subsys_6b180070&rev_04#6&326eda8f&0&001000e4#
Apr 12, 2021 22:03:44.822 [34728] INFO - [I] DeviceGetListEx_impl: pDL->Count:4
Apr 12, 2021 22:03:44.828 [34728] DEBUG - [I] BDA: get_tuner_type_from_filter. Unknown guid type {71985F4C-1CA1-11D3-9CC8-00C04F7971E0}
Apr 12, 2021 22:03:44.828 [34728] DEBUG - [I] BDA: get_tuner_type_from_filter: ATSC
Apr 12, 2021 22:03:44.828 [34728] DEBUG - [I] BDA: get_tuner_type_from_filter: DVB-C/CQAM
Apr 12, 2021 22:03:44.828 [34728] INFO - [I] BDA get_tuner_type. Detected type(s) 24 for device @device:pnp:\\?\pci#ven_14f1&dev_8880&subsys_6a180070&rev_04#6&edf7b30&0&000800e4#{71985f48-1ca1-11d3-9cc8-00c04f7971e0}\{9f0e8b98-c677-11db-beb4-00a0c9f21fc7}
Apr 12, 2021 22:03:44.830 [34728] DEBUG - [I] BDA: get_tuner_type_from_filter. Unknown guid type {71985F4C-1CA1-11D3-9CC8-00C04F7971E0}
Apr 12, 2021 22:03:44.830 [34728] DEBUG - [I] BDA: get_tuner_type_from_filter: ATSC
Apr 12, 2021 22:03:44.830 [34728] DEBUG - [I] BDA: get_tuner_type_from_filter: DVB-C/CQAM
Apr 12, 2021 22:03:44.830 [34728] INFO - [I] BDA get_tuner_type. Detected type(s) 24 for device @device:pnp:\\?\pci#ven_14f1&dev_8880&subsys_6a180070&rev_04#6&edf7b30&0&000800e4#{71985f48-1ca1-11d3-9cc8-00c04f7971e0}\{9f0e8b90-c677-11db-beb4-00a0c9f21fc7}
Apr 12, 2021 22:03:44.831 [34728] DEBUG - [I] BDA: get_tuner_type_from_filter. Unknown guid type {71985F4C-1CA1-11D3-9CC8-00C04F7971E0}
Apr 12, 2021 22:03:44.831 [34728] DEBUG - [I] BDA: get_tuner_type_from_filter: ATSC
Apr 12, 2021 22:03:44.831 [34728] DEBUG - [I] BDA: get_tuner_type_from_filter: DVB-C/CQAM
Apr 12, 2021 22:03:44.831 [34728] INFO - [I] BDA get_tuner_type. Detected type(s) 24 for device @device:pnp:\\?\pci#ven_14f1&dev_8880&subsys_6b180070&rev_04#6&326eda8f&0&001000e4#{71985f48-1ca1-11d3-9cc8-00c04f7971e0}\{9f0e8b90-c677-11db-beb4-00a0c9f21fc7}
Apr 12, 2021 22:03:44.832 [34728] DEBUG - [I] BDA: get_tuner_type_from_filter. Unknown guid type {71985F4C-1CA1-11D3-9CC8-00C04F7971E0}
Apr 12, 2021 22:03:44.832 [34728] DEBUG - [I] BDA: get_tuner_type_from_filter: ATSC
Apr 12, 2021 22:03:44.832 [34728] DEBUG - [I] BDA: get_tuner_type_from_filter: DVB-C/CQAM
Apr 12, 2021 22:03:44.832 [34728] INFO - [I] BDA get_tuner_type. Detected type(s) 24 for device @device:pnp:\\?\pci#ven_14f1&dev_8880&subsys_6b180070&rev_04#6&326eda8f&0&001000e4#{71985f48-1ca1-11d3-9cc8-00c04f7971e0}\{9f0e8b98-c677-11db-beb4-00a0c9f21fc7}
Apr 12, 2021 22:03:44.832 [34664] INFO - [I] dvb_device_factory_t::get_device_list. Id dvb#bda#0#@device:pnp:\\?\pci#ven_14f1&dev_8880&subsys_6a180070&rev_04#6&edf7b30&0&000800e4#{71985f48-1ca1-11d3-9cc8-00c04f7971e0}\{9f0e8b98-c677-11db-beb4-00a0c9f21fc7}, Name Hauppauge WinTV 885 ATSC Tuner/Demod 2, Standards 24
Apr 12, 2021 22:03:44.832 [34664] INFO - [I] dvb_device_factory_t::get_device_list. Id dvb#bda#0#@device:pnp:\\?\pci#ven_14f1&dev_8880&subsys_6a180070&rev_04#6&edf7b30&0&000800e4#{71985f48-1ca1-11d3-9cc8-00c04f7971e0}\{9f0e8b90-c677-11db-beb4-00a0c9f21fc7}, Name Hauppauge WinTV 885 ATSC Tuner/Demod, Standards 24
Apr 12, 2021 22:03:44.832 [34664] INFO - [I] dvb_device_factory_t::get_device_list. Id dvb#bda#0#@device:pnp:\\?\pci#ven_14f1&dev_8880&subsys_6b180070&rev_04#6&326eda8f&0&001000e4#{71985f48-1ca1-11d3-9cc8-00c04f7971e0}\{9f0e8b90-c677-11db-beb4-00a0c9f21fc7}, Name Hauppauge WinTV 885 ATSC Tuner/Demod, Standards 24
Apr 12, 2021 22:03:44.832 [34664] INFO - [I] dvb_device_factory_t::get_device_list. Id dvb#bda#0#@device:pnp:\\?\pci#ven_14f1&dev_8880&subsys_6b180070&rev_04#6&326eda8f&0&001000e4#{71985f48-1ca1-11d3-9cc8-00c04f7971e0}\{9f0e8b98-c677-11db-beb4-00a0c9f21fc7}, Name Hauppauge WinTV 885 ATSC Tuner/Demod 2, Standards 24
Apr 12, 2021 22:03:44.832 [34664] DEBUG - [I] file_tuner::get_stream_file. File F:\Plex Server\Resources\Tuner\Private\devices\dvb\file\drv_file.ini does not exist
Apr 12, 2021 22:03:44.832 [34664] INFO - [I] device_manager_t::get_device_list. Device Hauppauge WinTV 885 ATSC Tuner/Demod 2, id dvb#bda#0#@device:pnp:\\?\pci#ven_14f1&dev_8880&subsys_6a180070&rev_04#6&edf7b30&0&000800e4#{71985f48-1ca1-11d3-9cc8-00c04f7971e0}\{9f0e8b98-c677-11db-beb4-00a0c9f21fc7}, tuners 1, state 0, standards 24
Apr 12, 2021 22:03:44.832 [34664] INFO - [I] device_manager_t::get_device_list. Device Hauppauge WinTV 885 ATSC Tuner/Demod, id dvb#bda#0#@device:pnp:\\?\pci#ven_14f1&dev_8880&subsys_6a180070&rev_04#6&edf7b30&0&000800e4#{71985f48-1ca1-11d3-9cc8-00c04f7971e0}\{9f0e8b90-c677-11db-beb4-00a0c9f21fc7}, tuners 1, state 0, standards 24
Apr 12, 2021 22:03:44.833 [34664] INFO - [I] device_manager_t::get_device_list. Device Hauppauge WinTV 885 ATSC Tuner/Demod, id dvb#bda#0#@device:pnp:\\?\pci#ven_14f1&dev_8880&subsys_6b180070&rev_04#6&326eda8f&0&001000e4#{71985f48-1ca1-11d3-9cc8-00c04f7971e0}\{9f0e8b90-c677-11db-beb4-00a0c9f21fc7}, tuners 1, state 0, standards 24
Apr 12, 2021 22:03:44.833 [34664] INFO - [I] device_manager_t::get_device_list. Device Hauppauge WinTV 885 ATSC Tuner/Demod 2, id dvb#bda#0#@device:pnp:\\?\pci#ven_14f1&dev_8880&subsys_6b180070&rev_04#6&326eda8f&0&001000e4#{71985f48-1ca1-11d3-9cc8-00c04f7971e0}\{9f0e8b98-c677-11db-beb4-00a0c9f21fc7}, tuners 1, state 0, standards 24
Apr 12, 2021 22:03:44.833 [34664] INFO - [I] web_service_t::process_compound_devices. Merged 2 tuners for device dvb#bda#pci#ven_14f1&dev_8880&subsys_6a180070&rev_04#6&edf7b30&0&000800e4#
Apr 12, 2021 22:03:44.833 [34664] INFO - [I] web_service_t::process_compound_devices. Merged 2 tuners for device dvb#bda#pci#ven_14f1&dev_8880&subsys_6b180070&rev_04#6&326eda8f&0&001000e4#
Apr 12, 2021 22:03:44.834 [34664] INFO - [I] web_service_t::process_device_status
Apr 12, 2021 22:03:44.834 [34664] INFO - [I] device_reactor_t::get_device_list (dvb#bda#pci#ven_14f1&dev_8880&subsys_6a180070&rev_04#6&edf7b30&0&000800e4#)
Apr 12, 2021 22:03:44.834 [34664] INFO - [I] dvb_device_factory_t::get_device_list (dvb#bda#pci#ven_14f1&dev_8880&subsys_6a180070&rev_04#6&edf7b30&0&000800e4#)
Apr 12, 2021 22:03:44.838 [34724] INFO - [I] DeviceGetListEx_impl: Filter [Hauppauge WinTV 885 ATSC Tuner/Demod 2]
Apr 12, 2021 22:03:44.838 [34724] INFO - [I] DeviceGetListEx_impl: device instance path pci#ven_14f1&dev_8880&subsys_6a180070&rev_04#6&edf7b30&0&000800e4#
Apr 12, 2021 22:03:44.838 [34724] INFO - [I] DeviceGetListEx_impl: Filter [Hauppauge WinTV 885 ATSC Tuner/Demod]
Apr 12, 2021 22:03:44.838 [34724] INFO - [I] DeviceGetListEx_impl: device instance path pci#ven_14f1&dev_8880&subsys_6b180070&rev_04#6&326eda8f&0&001000e4#
Apr 12, 2021 22:03:44.838 [34724] INFO - [I] DeviceGetListEx_impl: pDL->Count:4
Apr 12, 2021 22:03:44.839 [34664] INFO - [I] dvb_device_factory_t::get_device_list. Id dvb#bda#0#@device:pnp:\\?\pci#ven_14f1&dev_8880&subsys_6a180070&rev_04#6&edf7b30&0&000800e4#{71985f48-1ca1-11d3-9cc8-00c04f7971e0}\{9f0e8b98-c677-11db-beb4-00a0c9f21fc7}, Name Hauppauge WinTV 885 ATSC Tuner/Demod 2, Standards 24
Apr 12, 2021 22:03:44.839 [34664] INFO - [I] dvb_device_factory_t::get_device_list. Id dvb#bda#0#@device:pnp:\\?\pci#ven_14f1&dev_8880&subsys_6a180070&rev_04#6&edf7b30&0&000800e4#{71985f48-1ca1-11d3-9cc8-00c04f7971e0}\{9f0e8b90-c677-11db-beb4-00a0c9f21fc7}, Name Hauppauge WinTV 885 ATSC Tuner/Demod, Standards 24
Apr 12, 2021 22:03:44.839 [34664] INFO - [I] device_manager_t::get_device_list. Device Hauppauge WinTV 885 ATSC Tuner/Demod 2, id dvb#bda#0#@device:pnp:\\?\pci#ven_14f1&dev_8880&subsys_6a180070&rev_04#6&edf7b30&0&000800e4#{71985f48-1ca1-11d3-9cc8-00c04f7971e0}\{9f0e8b98-c677-11db-beb4-00a0c9f21fc7}, tuners 1, state 0, standards 24
Apr 12, 2021 22:03:44.839 [34664] INFO - [I] device_manager_t::get_device_list. Device Hauppauge WinTV 885 ATSC Tuner/Demod, id dvb#bda#0#@device:pnp:\\?\pci#ven_14f1&dev_8880&subsys_6a180070&rev_04#6&edf7b30&0&000800e4#{71985f48-1ca1-11d3-9cc8-00c04f7971e0}\{9f0e8b90-c677-11db-beb4-00a0c9f21fc7}, tuners 1, state 0, standards 24
. . . . Help?!
