HD HomeRun - Could Not Tune Channel
New Plex user here - I’ve looked through the help articles without much luck. Also searched the forums and and although I see lots of problems, didn’t see something that was exactly the same as my issue. So trying a posting here.
Problem- When trying to watch local live TV & DVR (any channel) from my Plex Media Server (either Firefox or Chrome) with HD Homerun tuner I get the error:
Playback Error
Could not tune channel. Please check your tuner or antenna.
Configuration:
What works:
  • Using the HD HOmeRun Config utility I can scan channels and select “view” to watch a channel and playback is flawless (tuner works)!
  • Plex Media Server auto recognized the HD Homerun and I was able to successfully scan channels
  • Plex Media Server Channel Sources - Tuner Status for both tuners show green dots
  • Plex Movies & Shows, Live TV all work fine
What DOESN’T work:
  • local live TV & DVR (any channel) from my Plex Media Server (either Firefox or Chrome) with HD Homerun tuner I get the error
  • Also tried from Plex on Android and got similar error
Any help or clues appreciated!
Those directions don’t account for the ports required for Live TV & DVR which are a mixture of static and dynamic. As a test, disable the firewall to see if this is the issue. sudo ufw disable
Other common problem with TV & DVR will be the permissions on the directory.
ls -la the top of the library locations and post output.
