After subscribing to Plex pass and adding the HDHomeRun tuner, doing the channel scan. I can see the channels in Plex, but when I go to watch them it just freezes. In most cases it doesn’t even load the picture, but in some cases it will show a screen shot of the picture and not actually start playing when I hit the play button. I don’t have this problem when using the HDHomeRun - the app works perfectly and plays all the channels just fine.
Config:
NAS: QNAP TS-451A hard wired to router (Apple Airport (latest gen))
HD Homerun Connect duo - wired to outdoor HDTV antenna, plugged into an Airport express wifi repeater (because the antenna wiring is not near my router, I have the connect duo in my bedroom plugged into ethernet on an airport express repeater)
Apps tried:
Plex on iPhone 10 plex.tv in web browser on my mac (firefox)
Plex on Amazon FireTV (not the stick, the actual box)
Same problem here… even if you do “delete DVR” it still doesn’t work. And it doesn’t really get rid of everything either. I wish I could totally clear our the DVR cobwebs and set it up all over again if it would solve the problem… but I don’t know where they are hiding.
