HDHomerun Connect 4K no longer Showing up - Mac
Live TV and DVR was working fine a week ago. PMS no longer finds tuner. Deleted tuner in an attempt to re-add
Plex Tuner Service.log (34.4 KB)
and now it can’t find the tuner even entering the IP address manually. Is there any file I need to delete from the old tuner first?
Server Version#: Version 1.23.5.4841
Player Version#: Version 1.33.0.2444-a220eae4
Tuner Make/Model: HDHomeRun CONNECT 4K HDHR5-4K
Guide/Lineup name:
Using XMLTV?:
Channel number/Name:
Have you tried power cycling your HDHomeRun and then make sure it’s firmware is up to date
Yep, have the latest HDHomerun software per SiliconDust website, power cycled HDHomerun and it the tuner comes in fine on their software.
Same issue here. LiveTV worked last night. Upgraded firmware today and can no longer connect to my hdhomerun prime HDHR3-CC. Tried power cycling everything, same issue. Likely an issue with the latest Plex firmware.
Same issue with HDHomerun. No plex, SiliconDust software works fine. Have restarted everything.
