I had to replace my tuner. Plex sees it, sees the few 4K channels we get, guide loads, etc. But when you try to place, you get “Could not tune the channel. Please check your tuner or antenna”.
Works fine on the HDHomeRun app, locally on my server or on my remote devices. My server is absolute overkill for Plex (12th Gen i5, very fast M.2 SSD, 32GB Ram, 3070ti video card). I can stream or transcode large 4k files with ease. The same server worked fine with the old tuner. Yes, I deleted the old tuner and started fresh.
Not sure where to TS from here. This sure seems like a Plex issue and not a HDHomeRun issue…
