Can't Stream Live TV on Plex (HD Homerun FLEX 4k)
Server Version#: 1.25.2.5319
Player Version#: Web 4.72.0, Current iOS7.26/tvOS 7.26
Tuner Make/Model: HD HomeRun FLEX 4K)/Antenna
Guide/Lineup name:
Using XMLTV?:
Channel number/Name: All
Starting last night, I am unable to watch live TV in PLEX, while the HDHomeRun app runs fine natively. All I get is the spinning cursor when I select any channel. This is happening in Safari, iOS, and tvOS (apple TV 4K).
I have tried deleting and reinstalling the DVR and HD HomeRun and refreshed the guide to no avail.
Any suggestions?
Was this working before? AFAIK, Plex doesn’t support ATSC 3.0 yet.
It worked for several weeks. Stopped last night.
Did you try a non 4k channel? I’m pretty sure those won’t work, but regular ones might.
No channels work. All channels worked yesterday.
(all OTA here is HD, with the subchannels SD)
Maybe a clue…
I deleted the DVR again and in trying to re-add the HomeRun device, I’m stuck on this screen.
Have you tried restarting the DVR? unplug from power, plug it back in
If by DVR you mean the HD HomeRun FLEX, I did that this morning, and again just now.
Same result
Looks like PMS is having trouble talking to the HDHR. Have you restarted your computer? Maybe your router too?
Did a restart on the NAS and the HDHomeRun and guide added back normally.
TV playback is also good now. Should have done the restart first. Thanks for your patience.
Drew
