I’m running Plex DVR beta 4, on MacOS 10.12.2, with an HD Home Run Extend, which I have set to transcode at highest quality, and process video while recording. Sources that are 1080i, when played back, are done so as 1080p and exhibit terrible interlacing artifacts.
I can change transcoding to a lower setting (like High Quality 30 FPS) but that actually transcodes to 720p. Which brings up another issue; that should be labelled as such, since the other options indicate what the final format will be.
Anywho, this mismatch is a problem.
Media
Video Resolution 1080p
Width 1920
Height 1080
Aspect Ratio 1.78
Container MKV
Video Frame Rate NTSC
Web Optimized No
Begin Offset 2376
End Offset 1019
Video Profile high
Deleted At 1481902989
Part
File “Today (1952) - 2016-12-16 00 00 00 - Episode 12-16.mkv”
Size 227.80 MB
Container MKV
Web Optimized No
Video Profile high
Codec H264
Bit Depth 8
Chroma Subsampling 4:2:0
Color Range tv
Frame Rate 29.97 fps
Height 1080
Level 4.0
Profile high
Ref Frames 2
Scan Type interlaced
Width 1920
Codec AC3
Channels 5.1
Bitrate 384 kbps
Audio Channel Layout 5.1(side)
Sampling Rate 48000 Hz
I too have been running into really bad interlacing artifacts. I recently upgraded to Beta 4 and also upgraded the HDHomeRun firmware. Since then I recorded 2 shows and have not seen the interlacing. I’m going to be recording the show where the quality has been worst tomorrow and will let you know if it’s any better.
I just download the “Channels” app for Apple TV 4 (which by the way has a gorgeous grid view, live viewing and time shift), and it uses the raw stream from the HDHomeRun, which the Apple TV then hardware decodes. There is no problem with deinterlacing using this method, which leads me to believe that there’s a deinterlacing issue with Plex on playback.
It turns out that upgrading the firmware (and DVR to Beta 4) did NOT fix the problem. It seems like everything recorded at 1080 is interlaced, as per the info you pasted above. For me, the shows recorded at 720p look better. What is strange is that all of the shows I record at 1080p show a scan type of Interlaced.
Is there a way to find out if the source is interlaced? Is this an issue with the HDHomeRun? Or is it certain channels?
Finally, one issue I’m having is that I can’t find what channel a show was recorded on, so it’s hard to go and look at whether other shows on that channel have the same issue. When I look at what I think is the channel I recorded from in the HDHomeRunView app, I am not seeing the very visible interlace artifacts that I’m seeing for the recorded shows.
Keithus - how do you turn off processing and record to a .ts file? I had mine set for highest quality and was going to try it as “Original Format”. I also have “Process Video While Recording” checked.
