Server Version#: 4.132.2
Synology NAS DS423+
Docker Container
Hello, I’ve had some issues with Plex not HW transcoding some videos resulting in high CPU usage, I’ve noticed this only affects videos with HDR. If I turn off “Enable HDR Tone Mapping” Plex Dash shows the file is using HW transcoding but the file fails to play on my device. I receive the message “Something went wrong playing your media”
We need the Server DEBUG logs ZIP file which PMS gives you.
Ideal logs ZIP is:
- Settings - Server - General - Show Advanced
- Make certain DEBUG logging enabled and VERBOSE logging disabled.
SAVE if changed
- Now recreate the problem.
- Stop Playback
- Download the logs (Settings - Server - Troubleshooting - Download Logs)
- Attach (upload into the Reply windows) here.
Which host and kernel is this running on?
Not sure why you’re using Docker on Synology as it’s not needed for HDR transcoding anymore.
I see HW transcode here.
Jun 20, 2024 21:30:34.774 [140392412642104] DEBUG - [Req#9fe/Transcode/855DCD5B-2040-45DF-8FA2-C23012296C79] [FFMPEG] - Direct mapping possible.
Jun 20, 2024 21:30:34.775 [140392412642104] INFO - [Req#9fe/Transcode/855DCD5B-2040-45DF-8FA2-C23012296C79] Preparing driver ivd for GPU GeminiLake [UHD Graphics 600]
Jun 20, 2024 21:30:34.775 [140392412642104] DEBUG - [Req#9fe/Transcode/855DCD5B-2040-45DF-8FA2-C23012296C79/DriverDL/ivd] Skipping download; already exists
Jun 20, 2024 21:30:34.775 [140392412642104] DEBUG - [Req#9fe/Transcode/855DCD5B-2040-45DF-8FA2-C23012296C79] TPU: hardware transcoding: final decoder: vaapi, final encoder: vaapi
Jun 20, 2024 21:30:34.775 [140392412642104] DEBUG - [Req#9fe/Transcode/855DCD5B-2040-45DF-8FA2-C23012296C79/JobRunner] Job running: EAE_ROOT=/tmp/pms-1cb0c6fc-33b7-46ce-b6e9-f91f47afa660/EasyAudioEncoder FFMPEG_EXTERNAL_LIBS='/config/Library/Application\ Support/Plex\ Media\ Server/Codecs/ad47460-ffe81d9cd51bd27cb3fbbe09-linux-x86_64/' LIBVA_DRIVERS_PATH="/config/Library/Application Support/Plex Media Server/Cache/va-dri-linux-x86_64" X_PLEX_TOKEN=xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx "/usr/lib/plexmediaserver/Plex Transcoder" -codec:0 hevc -hwaccel:0 vaapi -hwaccel_fallback_threshold:0 10 -hwaccel_output_format:0 vaapi -hwaccel_device:0 vaapi -codec:1 truehd_eae -eae_prefix:1 855DCD5B-2040-45DF-8FA2-C23012296C79_ -analyzeduration 20000000 -probesize 20000000 -i "/datastorage/media/movies kids/Captain Underpants The First Epic Movie (2017)/Captain Underpants The First Epic Movie (2017) Bluray-2160p.mkv" -filter_complex "[0:0]hwupload[0];[0]scale_vaapi=w=720:h=388:format=nv12[1];[1]hwupload[2]" -map "[2]" -codec:0 h264_vaapi -b:0 1287k -maxrate:0 1716k -bufsize:0 3432k -r:0 23.975999999999999 -force_key_frames:0 "expr:gte(t,n_forced*3)" -filter_complex "[0:1] aresample=async=1:ochl='stereo':rematrix_maxval=0.000000dB:osr=48000[3]" -map "[3]" -metadata:s:1 language=eng -codec:1 aac -b:1 167k -segment_format mp4 -f ssegment -individual_header_trailer 0 -flags +global_header -segment_header_filename header -segment_time 3 -segment_start_number 0 -segment_copyts 1 -segment_time_delta 0.0625 -segment_list "http://127.0.0.1:32400/video/:/transcode/session/855DCD5B-2040-45DF-8FA2-C23012296C79/94411ab8-c46b-4a94-99c3-428a6ead503c/manifest?X-Plex-Http-Pipeline=infinite" -segment_list_type csv -segment_list_size 5 -segment_list_separate_stream_times 1 -segment_list_unfinished 1 -segment_format_options movflags=frag_custom+dash+delay_moov+frag_discont:fragment_index=1:output_ts_offset=10 -max_delay 5000000 -avoid_negative_ts disabled -map_metadata -1 -map_chapters -1 "media-%05d.ts" -start_at_zero -copyts -vsync cfr -init_hw_device vaapi=vaapi:/dev/dri/renderD128,driver=i965 -filter_hw_device vaapi -y -nostats -loglevel quiet -loglevel_plex error -progressurl http://127.0.0.1:32400/video/:/transcode/session/855DCD5B-2040-45DF-8FA2-C23012296C79/94411ab8-c46b-4a94-99c3-428a6ead503c/progress
Jun 20, 2024 21:30:34.775 [140392412642104] DEBUG - [Req#9fe/Transcode/855DCD5B-2040-45DF-8FA2-C23012296C79/JobRunner] In directory: "/config/Library/Application Support/Plex Media Server/Cache/Transcode/Sessions/plex-transcode-855DCD5B-2040-45DF-8FA2-C23012296C79-94411ab8-c46b-4a94-99c3-428a6ead503c"
Given the iPhone player does a lot of things itself, to rule out the phone app, what happens if you play in a browser ?
I recently changed to running in a container for automatic updates mostly.
I’ve just tried reverting back to the Synology package and its working fine now so I’m going to leave it at that.
Thanks for your help
