Hi BigWheel how are you ?
I upgrade recently my account to premium & need some help please …
I have a problem with Hebrew subtitles - RTL.
Any solution for that ? try to search info but couldn’t find something solid
I’ll be more than happy yo get support with this issue ![]()
Thanks in advance …
Shimon
What specific issue are you having? Which app is the issue happening in?
If you can provide a Hebrew - RTL subtitle file I can test with, it would be appreciated.
Hi ,
see attached link describing the same issue I’m talking about …
My server installed on AMD PC (windows 10) and my clients are Nvidia shield & Amazon 4K max on both of them the heb subtitles does not support RTL
I use Kodi till the day I meet PLEX
but this issue is annoying & I’ll be happy to solve it …
https://forums.plex.tv/t/hebrew-subtitles-punctuation-problem-in-apple-tv/217571
Thank you !
Shimi
Do you have a subtitle file I can test with? I did not see any in the links in the other topics. Are they embedded in the file? Do you now what type of subtitles you have; SRT, SSA etc?
BTW it showing the same issue when using “open subtitles” plugins from the PLEX without using external subtitle
Thx,Shimon
Any resolution after I send you the subtitle file ?
BTW - on the computer (windows) i don’t see the opposite RTL issue - is there something that we miss here ? I guess it’s an issue on an android client …
Thank you in advance !
Shimon
