Evidently my XEON 3.2Ghz CPU is not powerful enough to handle processing 4 Channels of HD (1080p), how can I set to record in SD (720P)? Note: It takes all of my CPU just to play a HD (1080p) recording.
PLEX MEDIA SERVER: 1.14.1.5488
On ROKU: 6.1.1.5282-4907f3688-Plex
I’m using a HP Z400 (64 bit Window 7 Professional, XEON 3.2Ghz, 8GB RAM, 1TB HD, Ethernet Connection) as a server. There’s basically nothing on the computer except PLEX and HDHomeRunDVR Software. The sole purpose of the server is recording and watching OTA TV.
HDHomeRun CONNECT Quatro 1072A6EC Version 20180817
I found a link to upgrade to 10. As of 12/30/18 Windows 10 Professional
You mentioned that it is a HDHR 4 tuner model so assuming the Connect Quatro which does not have any transcoding ability built-in. The HDHR Extend is the only tuner device that has transcoding built-in. So your HDHR tuner device will not be able to do the transcoding itself.
Correct. Possibly some sort of post processing to reduce the resolution or finding clients that can Direct Play the material thereby eliminating the need for any transcoding by Plex.
Your Plex settings gives you the option for transcoder quality. Set that to auto. Also your window power schedule should be changed from conservative to performance.
Yes, go to your windows icon in the lower corner of the desktop screen option control panel, power and performance, and change from balanced to performance.
If you are having performance hits based on transcoding. This may help.
I changed to performance with no noticeable change. I then decided to take another approach and uninstalled PLEX in hopes of getting the HDHomeRun DVR app running. After 8 days of working with their support. HDHomeRun has not been able to resolve the issue (their website still indicates the DVR is operation, but their app says “No DVR Configured”). Their site says:
“Use of 3rd Party Firewall/Security software may cause problems.
3rd party anti-virus software should not be used on the PC being used for recordings. It impedes performance and can block necessary network traffic. Native Windows software is sufficient.”
I uninstalled my Norton and still have the same issue with the HDHomeRun DVR app.
I would rather have PLEX, the DVR did record and try to playback but was to slow, and kept pausing to download every 30 sec. Could Norton have been the reason the DVR was slow with PLEX?
