During the pre 0.4.0 experimental releases, I was experiencing ethernet dropouts, to the point that I had abandoned my beloved Rasplex in favour of a Plexconnected ATV3 (which is a good solution for European TV shows, but the lack of 24Hz output is a showstopper for US stuff). All of this after having "upgraded" my power supply to a proper 5V/1.2A (which I have tested with a multimeter).
With the latest release out, I tried again, and Rasplex is back on my TV.
Given that I have read success stories with high-bitrate 1080p movies (by high I mean > 10 Mbit/s, which were previously unwatchable), I applied dlanor's overclocking settings (thanks dlanor).
After booting, Rasplex picked up immediately my PMS, pre-cached everything and I proceeded to customise my settings.
As soon as I scrolled to "Movies", the PMS disappeared, then reappeared one second later, and so on..
Going to the Connections section of the rasplex settings confirmed my suspicions. The ethernet connection was flashing every second.
So I decided to overvolt by 2 instead of 4. The dropouts were even more frequent.
Disabling overvolting prevented the Pi to boot (black screen after the Rasplex logo).
Now, I set it to 1. Dropouts are less frequent, but I actually managed to start playback once.
While I am fully aware that I am treading on thin ice, my question is: why does the dropout always occur when browsing the library (most of the times when I scroll to Movies or TV Shows without selecting the section) and never during playback?
Is there something I can do to better diagnose the problem?
Thanks a lot.
