Help! How do I change my username?
For some reason Plex defaulted my username to my email address and I can’t find any way to change it! That is lame!!!
https://plex.tv/users/edit
Thank you! Here I am trying to change my username in the forum. I see this has apparently happened to others as well, judging by their usernames. It’s not a problem to login to Plex with an email address unless you’re using the forum. I think this needs to be changed.
You can continue to login to Plex with an email address.
Just tick the checkbox in the same place.
The forum will use the ‘user name’, Plex clients will use the email adddress.
