Help installing PlexPy
I’ve been asking around for help with installing PlexPy. I tried to use docker, but I could not get the settings to save properly on a reboot of NAS. I tried to install via PlexPys Linux instructions but on a reboot I can no longer find the /opt/PlexPy directory.
Would like some step by step help.
@timstephens24 provided the fix.
Solution:
I did all this from root.
First thing I did was install git, so I could git clone the repo. I did that by installing the Git Server from Synology. Then I made a folder called repos in root’s home directory:
cd; mkdir repos; cd repos
git clone https://github.com/drzoidberg33/plexpy.git
I made this file to run the command to start PlexPy: /usr/local/start/plexpy.start.sh
/usr/bin/python /root/repos/plexpy/PlexPy.py > /dev/null 2>&1 &
I made a startup script: /usr/syno/etc.defaults/rc.d/S99plexpy.sh
RETVAL=0
start() {
echo -n "Starting PlexPy: "
ps | grep PlexPy.py | grep python
RETVAL=$?
[ $RETVAL -eq 0 ] && echo “PlexPy already running: Exiting” && exit 1
/bin/sh /usr/local/start/plexpy.start.sh > /dev/null 2>&1 &
RETVAL=$?
[ $RETVAL -eq 0 ] && echo -n “done”
echo
return $RETVAL
stop() {
echo -n “Stopping PlexPy: "
kill -9 ps |grep PlexPy.py |grep python | awk -F” " ‘{print $1}’
RETVAL=$?
echo
echo
return $RETVAL
case $1 in
start)
start
stop)
stop
restart)
stop
sleep 1
start
RETVAL=$?
echo “Usage: $0 [start|stop|restart]”
exit 1
esac
exit $RETVAL
And lastly make both of them executable
chmod +x /usr/syno/etc.defaults/rc.d/S99plexpy.sh /usr/local/start/plexpy.start.sh
Now it will start at boot, and you can also start/stop/restart it with the following commands:
/usr/syno/etc.defaults/rc.d/S99plexpy.sh start
/usr/syno/etc.defaults/rc.d/S99plexpy.sh stop
/usr/syno/etc.defaults/rc.d/S99plexpy.sh restart
Glad it helped you!
Thanks for this. I found a straight copy paste of S99plexpy.sh resulted in the stop command not working. It was failing to extract the correct pid to kill. I fixed it by replacing the following line:
kill -9 ps |grep PlexPy.py |grep python | awk -F" " ‘{print $1}’
with the below
kill -9 $(ps | grep PlexPy.py | grep python | awk -F " " ‘{ print $1 }’)
Otherwise, thanks for figuring this out!
A follow up question - have you managed to get HTTPS working? It appears that PlexPy needs the pyOpenSSL module installing separately, any idea how to do that?
with the below
I can not take credit for this. A fellow user (@timstephens24) in the PlexPy thread provided the guide.
Thanks for noticing an issue, guess I haven’t tried to stop it yet :slight_smile:
I would ask and follow this post - it’s a Q&A for PlexPy.
with the below
Apparently the forums stripped out part of the command and I didn’t notice it. My command was yours but I used the backticks instead of $().
I think I did a poor job of cutting and pasting. If you want to double check go to the bottom of this post. :slight_smile:
can any one confirm this works on sinology patflorm
you can use pip to install python modules that are needed using something like ‘pip install pyOpenSSL’
Hi, if you use docker (https://github.com/linuxserver/docker-plexpy) you need to map the /config directory to a directory on your filesystem, otherwise the settings will be lost on each pull of a new docker image.
@CornholioLU said:
Hi, if you use docker (GitHub - linuxserver/docker-tautulli) you need to map the /config directory to a directory on your filesystem, otherwise the settings will be lost on each pull of a new docker image.
Can you explain how to do that please? Unfortunately I have no idea what I’m doing.
Before I saw this thread I came up with a simpler solution that works fine for me. But might not be as technically correct as some of the ones posted here.
I just extracted the PlexPy file from the downloaded archive on git into a folder onto my NAS, and then I made a simple script that I also placed somewhere on the NAS and named it “PlexPy_Start.sh”:
#!/bin/sh
# Check if already running, if not then run
if  ps | grep -v grep | grep -q PlexPy.py; then
    :            # do nothing if already running
else
    python "/volume1/Plex/PlexPy/PlexPy.py" &
fi
In the Task Scheduler in the DSM interface I made a task which runs this script every 5 minutes or so, making sure that the PlexPy restarts if it for some reason would crash it also starts it on reboot (worst case with a delay of 5 minutes after boot).
Regarding updating the PlexPy you do not need git on the NAS since the PlexPy interface will tell you when there is a new version and it also gives you a button to press to automatically update to the latest version.
I’ve been trying to get this to work all day and having no success at all. Running Xpenology / Synology DSM 5.2 on HP MicroServer Gen8.
Running /usr/syno/etc.defaults/rc.d/S99plexpy.sh start
or
Results in:
: not foundtc.defaults/rc.d/S99plexpy.sh: line 7:
: not foundtc.defaults/rc.d/S99plexpy.sh: line 10: echo
/usr/syno/etc.defaults/rc.d/S99plexpy.sh: return: line 11: Illegal number: 127
This is very odd… line 10 is just “echo” and line 11 is just “return $RETVAL”
Please help!!
deleted wrong thread
Assuming you have Docker installed on your NAS.
  • Open Docker in DSM
  • Go to “Image” tab
  • Click Add, Add From URL, enter https://registry.hub.docker.com/u/linuxserver/plexpy/, then click Add
  • Make a folder somewhere that PlexPy can keep its saved config. I made a plexpy folder in the docker shared folder (/volume3/docker/plexpy). I also make a textfile /volume3/docker/timezone containing just your TZ, in my case “Pacific/Auckland” (no quotes) so that the docker container would pick up the correct time (see volume mapping below).
  • SSH into your Synology and run the following,
    docker run \ --name="plexpy" \ -p 8183:8181 \ --volume=/etc/localtime:/etc/localtime:ro \ --volume=/volume3/docker/timezone:/etc/timezone:ro \ --volume=/volume3/docker/plexpy/config:/config \ --volume="/volume3/Plex/Library/Application Support/Plex Media Server/Logs":/logs:ro \ -e PUID=1026 \ -e PGID=100 \ --restart=always \ --detach \ linuxserver/plexpy
Notes
  • Be aware of users and permissions.
  • Change and names, paths and ports to suit your environment.
  • -p, exposed port:internal port, i.e. connect to http://nas-ip:8183
  • --volume=/volume3/docker/plexpy:/config, is where you want plexpy to save it’s config so it persists between reboots
  • --volume="/volume3/Plex/Library/Application Support/Plex Media Server/Logs":/logs:ro, is the location of your PMS log folder and mapped location in the docker container (/logs)
  • -e PUID=1026, a user’s uid to run the docker container as with read/write to plexpy config folder and read access to the PMS logs, you may have set some permission either in the DSM Control Panel or via SSH
  • -e PGID=100, a gid (groupid) for the UID above
  • --restart=always, so that if the container exits, Docker will restart it.
  • --detach run in background
  • linuxserver/plexpy, the docker image
Give it a minute or two to get fired up and it’ll show in your Docker Container tab where you can then stop/start/edit to your heart’s content. Open PlexPy in your browser on http://nas-ip:8183 and configure as required. Be sure to set your Settings for Plex Media Server → Plex IP or Hostname to the IP address/hostname of the machine running PMS - 127.0.0.1 won’t do as the docker container isn’t running Plex. Also be sure Logs Folder is set to /logs. Set your Plex.tv Account by fetching a token (you’ll see on the Plex.tv Account setting page).
@artiss The method you describe above is not working on the latest DSM 6 beta 2. It worked flawlessly on DSM 5 but something changed. I know its a beta but if anyone has a heads up on what needs to change to get it to work on DSM 6, we can get ahead of the curve here. Thanks!
@dankster - I have pretty much the above running on DSM6.0RC without problem. A few mods to the S99 script and created some symlinks to git, but working fine…
Spoke to soon. Updated DSM6.0RC to full version and wiped out my PlexPy. Guess I should have not used the defaults directories. Any how, reinstalled and all working again. Some details as follows:
did the ‘git pull’ into this directory: /volume1/@appstore/plexpy/PlexPy.py
created start script here: /usr/local/start/plexpy.start.sh
and added startup script here: /usr/syno/etc.defaults/rc.d/S99plexpy.sh
Also changed the line:
to
kill -9 $(ps -ef | grep PlexPy | grep -v grep | awk ‘{print $2}’)
Now running just fine. Have Plex, PlexPy and SickRage all doing their job happily. Only thing I haven’t sorted is PlexConnect for ATV3 yet.
@rjblake thanks for the follow up my man. can you tell me which user you logged in via ssh with? i think my issue is the symlinks or something…
UPDATE:
i was able to get it to run by sshing in as Admin then “Sudo su -” which switched me to root. i then followed the directions above and it seems to be working!
