HELP! Issues with Mesh Wifi Network
Hi I’m having this very strange issue when I connect my server to my home mesh wifi router, it thinks it’s outside my home area and resorts to remote access with terrible quality.
When I switch to the router from my ISP and use say my TV on the same wireless network from my ISP everything is fine, but I have many devices including my PC connected to my Wifi Mesh system via Ethernet and cannot get the issue to stop happening. Any tips or advice for this issue? I’ve been searching google and reddit to no avail, any help would be appreciated so I can enjoy my content again!
Can you change your ISP provider router to bridge mode and use 192.168.1.1 LAN ip on main mesh router?
Or try to set your mash LAN ip/mask in server network settings:
A comma-separated list of IP addresses or IP/subnet mask entries for networks that will be treated as local when applying bandwidth limits. If set, all other IP addresses will be treated as external networks and will be subject to external network bandwidth limits. If left blank, only the server subnet is considered the local network.
