hd homerun sells tuner boxes that can tune in channels OTA (ie local channels from your antenna) and they also have a âpremiumâ service which is like netflix or slingtv or direc tv now, or any other âstreamingâ services.
silicon dust is actually the company, hd homerun is the brand of tuners they sell.
Once you buy the hd homerun tuner box and connect your antenna and plug the box into your home network, you can access the tuner box in several ways;
- you can directly access the HDHR tuner by webpage direct to the box
- you can use HDHR software on your pc (which connects to your tuner box) and gives you a fancy interface for live tv and optional dvr service
- you can use other 3rd party software to access tuner box and either watch live tv and/or provide their own dvr service
plex does the last option, it connects to the tuner box and lets you watch live tv from any plex client, and you can configure the dvr to record the live channels to your plex library
so, buying the hdhr box gets you free ota local tv with no other costs
if you want the other stuff, either the hd hr dvr software, or the hd hr âpremiumâ streaming service, that costs money to the hd hr people (not part of plex)
or with plex pass + tuner box you have live tv + drv, all integrated with your other media on plex
FWIW I have not heard of a house antenna, I would suggest you buy a real antenna and either put it in your attic or have it installed outside your house, if you want the best local channel performance.
Personally I use the hd homerun quatro (it has 4 tuners, so I can watch or record up to 4 different channels at the same time.
I also have the $30 antenna linked below hanging in my attic, which works great for me and my area.
https://www.amazon.com/gp/product/B00DNJZ58M/ref=oh_aui_search_asin_title?ie=UTF8&psc=1
