[Help Needed] "Combine" 02 Libraries? Is that Possible?
Hi all!
So i just realize that i create so many different libraries (07) that is hard to anyone find something in my server. I am thinking to reduce this number to 3 or 4 but i already customize everything and don´t want to do the job again.
See:
I know i can use filters… but i want just to create like “New movies” and “Old Movies” and then search for the movie using the filter
Is there a way to combine libraries? So i can keep all the data?
THX,
Braz.
In short, no. You can’t merge libraries together.
Thank you @“Bartlomiej Baraniec” for your help :frowning:
I will do it again
