Combine 2 Libraries
I added 62 movies the a folder called movies and it went perfectly. Well I added 4 more movies and it created a new library called movies. So now I have 2 folders under libraries called Movies. Is there a way to combine the 2 libraries? Also the next time I add new movies how to I add them to the current folder called Movies? Thanks
I figured it out, I just moved the movies into the same folder on my external hard drive and did a update library.
