How can I have extras (like behind the scenes / interviews and trailers) when i update my lmovie library?
Can i do that with TV Series too?
I did not find any option that enable this feature.
THX,
Braz.
THX,
Braz.
Check out the bottom of https://support.plex.tv/hc/en-us/articles/200220677-Local-Media-Assets-Movies.
You cannot add extras to TV Shows.
That’s good for adding local asset extras, but there’s this page also for non-local extra content:
https://support.plex.tv/hc/en-us/articles/202934883-Cinema-Trailers-Extras
Ok THX but I will need to re-create my libraries or i can add this feature to the one that i already have?
Once you set the options, the extras should get pulled upon a Refresh.
Please start small, try first with a few high-profile Hollywood movies and refresh them individually.
Wait a few minutes after pressing Refresh.
you’ll have bother with thumbnails on the local extras if your data is not local or network drive mapped. UNC paths causes a failure in loading a thumbnail. Just an FYI.
I’ve never seen this problem. Is there a thread about it or just a personal observation?
Already filed.
Hi!
Thanks @MovieFan.Plex @OttoKerner @beckfield @Liquidtoon
I will try to change the settings in my smallest library to see… I Really don´t get what @Liquidtoon said but all my data is in local drive. I already create one new library with the instructions links and it works fine. Now i will try to change another library. Let all know asap.
Thank you all
Braz.
@BrazMan said:
Hi!
Thanks @MovieFan.Plex @OttoKerner @beckfield @LiquidtoonI will try to change the settings in my smallest library to see… I Really don´t get what @Liquidtoon said but all my data is in local drive. I already create one new library with the instructions links and it works fine. Now i will try to change another library. Let all know asap.
Thank you all
Braz.
After try to refresh… had no lucky to get the extras… So you have to create a new library!
Thank you all ![]()
Braz.
I wouldn’t state that in this absoluteness.
Did you use TheMovieDatabase before as your primary agent? If so, you go to
Settings - Server - Agents - Movies - TheMovieDatabase
in there, put a check in front of the line ‘Plex Movie’ (you don’t need to rearrange the order of agents)
Then Refresh one of the movies again.
@OttoKerner said:
@BrazMan said:
After try to refresh… had no lucky to get the extras… So you have to create a new library!I wouldn’t state that in this absoluteness.
Ok! It works ![]()
THX,
Braz.
