Hi all!
Here the info:
Server Version#: 1.19.1.2645
Player Version#: 2,16
I don´t know exacly how to explain my problem but only in appletv (non 4K) happens:
Just after i start to play any file it´s seems that the enhanced player is loosing some image frames and looks like slow motion for a few seconds then goes back to normal play and repeat the same thing over and over. I am running on wired local network (100 mbits) with direct play. Files are mostly H.264 1080p no 4k. This also happens in remote plays.
I have 02 AppleTV… If a play the same files on other devices (android or SamsungTV) it plays smoothly.
I already uninstall the app, change the network cable, downgrade pms to the version listed above and still i was not able to fix this.
Here pictures of my settings:
I hope someone can help me with this ![]()
THX,
Braz.
