Help Please! - I can't seem to figure this one out
I am not able to access http://IPserver:32400/web. I get the This page isn’t working right now response. I have read through most of the suggestions mostly to the point of sending log files and even browsed through the files trying to look for something obvious to research. My amateur opinion is it has something to do with the router and some conflict with the 32400 port but I can’t find it or any reference to anyone else having this problem.
Thanks in advance for any help.
If you’re still on DSM 6 (fingers crossed)
This will help you get the log files manually.
If you’ll get and post them, we can look further and see what is going on.
Thanks for the quick response, here they are (File removed)
Thanks Chuck, great information. I think I tracked down the redundant ethernet and went through the steps above. Still no luck. Also, I am new to Plex if there is a general uninstall, reinstall, that would be fine with me.(File removed)
Have you restarted DSM & Plex since you found the redundant ethernet?
Your logs (just posted) still show ETH0 and ETH1 at the same address.
This is bad.
Dec 27, 2020 19:04:41.822 [0x7fec14e50780] DEBUG -  * 8 ovs_eth0 (10.0.4.2) (loopback: 0)
Dec 27, 2020 19:04:41.822 [0x7fec14e50780] DEBUG -  * 9 ovs_eth1 (10.0.4.2) (loopback: 0)
At minimum, while still not desired, make them 10.0.4.2 and 10.0.4.3 and set ETH0 as the Default Gateway
I think there were some later logs or i grabbed the wrong one. This should show it’s fixed, I hope. Thanks again for all the help.(File removed)
This set of logs is showing me Plex bouncing all over the place because of the adapter changes. Let’s get it stable?
would you please restart DSM,
Let Plex sit for 4 minutes after you sing into DSM
After that time, just download the logs and attach here (I want PMS to pull the logs).
If not, Stop plex first then make another ZIP file (so the buffer is flushed to disk)
(File removed) I hope this helps. Thank you again for your patience.
thanks… that is looking better but we’re still not getting to what we need to see.
These logs show it going through a bunch of media and still ingesting it.
Dec 28, 2020 10:20:15.449 [0x7f901af80700] DEBUG - Updating metadata item (save) (Patrick Crabb) with ID 31483
Dec 28, 2020 10:20:15.457 [0x7f901bb38700] DEBUG - Analyzing media parts for item 31482 (Neil Moss): 31070
Dec 28, 2020 10:20:15.459 [0x7f901bb38700] DEBUG - [ID 31070] Media part analysis: /volume3/Shire Photo/Video movies/Neil Moss.mp4
Dec 28, 2020 10:20:15.460 [0x7f901bb38700] DEBUG - [MI] Opening input file: "/volume3/Shire Photo/Video movies/Neil Moss.mp4"
Dec 28, 2020 10:20:15.460 [0x7f901bb38700] DEBUG - [FFMPEG] - Opening '/volume3/Shire Photo/Video movies/Neil Moss.mp4' for reading
Dec 28, 2020 10:20:15.460 [0x7f901bb38700] DEBUG - [FFMPEG] - Setting default whitelist 'file,crypto'
Dec 28, 2020 10:20:15.460 [0x7f901bb38700] DEBUG - [FFMPEG] - Format mov,mp4,m4a,3gp,3g2,mj2 probed with size=2048 and score=100
Dec 28, 2020 10:20:15.460 [0x7f901bb38700] DEBUG - [FFMPEG] - ISO: File Type Major Brand: M4V
Dec 28, 2020 10:20:15.460 [0x7f901bb38700] DEBUG - [FFMPEG] - Unknown dref type 0x206c7275 size 12
Would it be possible to wait until everything has settled (CPU is idle)
then recreate / capture for me and grab those logs?
It looks dormant to me. (File removed) Thanks again
It’s still scanning media. These particular files generate a huge amount of output
Dec 28, 2020 11:03:21.852 [0x7f0b0111f700] DEBUG - Mp4AtomParser: Found 0x7000000 atom of size 29 at offset 5350395
Dec 28, 2020 11:03:21.852 [0x7f0b0111f700] DEBUG - Mp4AtomParser: Found data atom of size 21 at offset 5350403
Dec 28, 2020 11:03:21.852 [0x7f0b0111f700] DEBUG - Mp4AtomParser: Found 0x8000000 atom of size 33 at offset 5350424
Dec 28, 2020 11:03:21.852 [0x7f0b0111f700] DEBUG - Mp4AtomParser: Found data atom of size 25 at offset 5350432
Dec 28, 2020 11:03:21.852 [0x7f0b0111f700] DEBUG - Mp4AtomParser: Found 0x9000000 atom of size 28 at offset 5350457
Dec 28, 2020 11:03:21.852 [0x7f0b0111f700] DEBUG - Mp4AtomParser: Found data atom of size 20 at offset 5350465
Dec 28, 2020 11:03:21.852 [0x7f0b0111f700] DEBUG - Mp4AtomParser: Found 0xa000000 atom of size 48 at offset 5350485
Dec 28, 2020 11:03:21.852 [0x7f0b0111f700] DEBUG - Mp4AtomParser: Found data atom of size 40 at offset 5350493
Dec 28, 2020 11:03:21.852 [0x7f0b0111f700] DEBUG - [MI] Closing input file: "/volume3/Shire Photo/matt 11/IMG_2859.MOV"
Dec 28, 2020 11:03:21.853 [0x7f0b0111f700] DEBUG - Updating media item 16285, size=5350533, metadata_item_id=16370
Dec 28, 2020 11:03:21.853 [0x7f0b0111f700] DEBUG - Updating part with ID=16285 [/volume3/Shire Photo/matt 11/IMG_2859.MOV]
Dec 28, 2020 11:03:21.856 [0x7f0b0111f700] DEBUG - Updating metadata item (save) (IMG_2859) with ID 16370
Dec 28, 2020 11:03:21.857 [0x7f0b21c1e700] DEBUG - Updating metadata item (save) (IMG_2859) with ID 16370
Dec 28, 2020 11:03:21.860 [0x7f0b0111f700] DEBUG - Analyzing media parts for item 31443 (simple.m.ts.islb.se40.vmb): 31047
Dec 28, 2020 11:03:21.860 [0x7f0b0111f700] DEBUG - [ID 31047] Media part analysis: /volume3/Shire Photo/Storage/Work/Tech Track B/05B/simple.m.ts.islb.se40.vmb.avi
Dec 28, 2020 11:03:21.860 [0x7f0b0111f700] DEBUG - [MI] Opening input file: "/volume3/Shire Photo/Storage/Work/Tech Track B/05B/simple.m.ts.islb.se40.vmb.avi"
Dec 28, 2020 11:03:21.860 [0x7f0b0111f700] DEBUG - [FFMPEG] - Opening '/volume3/Shire Photo/Storage/Work/Tech Track B/05B/simple.m.ts.islb.se40.vmb.avi' for reading
Dec 28, 2020 11:03:21.860 [0x7f0b0111f700] DEBUG - [FFMPEG] - Setting default whitelist 'file,crypto'
Dec 28, 2020 11:03:21.860 [0x7f0b0111f700] DEBUG - [FFMPEG] - Format avi probed with size=2048 and score=100
Dec 28, 2020 11:03:21.860 [0x7f0b0111f700] DEBUG - [FFMPEG] - use odml:1
Dec 28, 2020 11:03:21.861 [0x7f0b0111f700] DEBUG - [FFMPEG] - Before avformat_find_stream_info() pos: 4096 bytes read:109204 seeks:4 nb_streams:1
Dec 28, 2020 11:03:21.861 [0x7f0b0111f700] DEBUG - [FFMPEG] - All info found
Dec 28, 2020 11:03:21.861 [0x7f0b0111f700] DEBUG - [FFMPEG] - After avformat_find_stream_info() pos: 27680 bytes read:109204 seeks:4 frames:1
Dec 28, 2020 11:03:21.861 [0x7f0b0111f700] DEBUG - [MI]  * d28a404fded3ec39c65b7ef0dd9019816817635e [avi msrle/] Duration: 32900ms, 1270x924 (1.374459) 10.000fps, bitrate=1899kbps, audio channels=0, optimizedForStreaming=0 ("/volume3/Shire Photo/Storage/Work/Tech Track B/05B/simple.m.ts.islb.se40.vmb.avi")
Dec 28, 2020 11:03:21.861 [0x7f0b0111f700] DEBUG - [MI] Chapters had generic titles, clearing.
Dec 28, 2020 11:03:21.861 [0x7f0b0111f700] DEBUG - Updating metadata item (save) (simple.m.ts.islb.se40.vmb) with ID 31443
Dec 28, 2020 11:03:21.862 [0x7f0b0111f700] DEBUG - [MI] Closing input file: "/volume3/Shire Photo/Storage/Work/Tech Track B/05B/simple.m.ts.islb.se40.vmb.avi"
Dec 28, 2020 11:03:21.863 [0x7f0b0111f700] DEBUG - Committing media stream changes for part 31047
Dec 28, 2020 11:03:21.863 [0x7f0b0111f700] DEBUG - Updating media item 31047, size=7810048, metadata_item_id=31443
Dec 28, 2020 11:03:21.863 [0x7f0b0111f700] DEBUG - Updating part with ID=31047 [/volume3/Shire Photo/Storage/Work/Tech Track B/05B/simple.m.ts.islb.se40.vmb.avi]
Dec 28, 2020 11:03:21.866 [0x7f0b0111f700] DEBUG - Updating metadata item (save) (simple.m.ts.islb.se40.vmb) with ID 31443
Dec 28, 2020 11:03:21.868 [0x7f0b21c1e700] DEBUG - Updating metadata item (save) (simple.m.ts.islb.se40.vmb) with ID 31443
Dec 28, 2020 11:03:21.871 [0x7f0b0111f700] DEBUG - MetadataItemClusterRequestHandler: 16 unclustered items have been processed
Dec 28, 2020 11:28:17.978 [0x7f0b0111f700] DEBUG - Sync: uploadStatus
Dec 28, 2020 11:28:30.592 [0x7f0b02e6b700] DEBUG - Putting plug-in com.plexapp.agents.imdb to sleep.
Dec 28, 2020 11:28:30.592 [0x7f0b02e6b700] DEBUG - Stopping [com.plexapp.agents.imdb].
Dec 28, 2020 11:28:30.592 [0x7f0b02e6b700] DEBUG - [com.plexapp.agents.imdb] Killing.
Dec 28, 2020 11:28:30.594 [0x7f0b28acc700] WARN - JobManager: Could not find job for handle 7733
Dec 28, 2020 11:28:40.593 [0x7f0b02e6b700] DEBUG - Stopping file watcher for com.plexapp.agents.imdb
Dec 28, 2020 11:58:17.978 [0x7f0b01cd7700] DEBUG - Sync: uploadStatus
Dec 28, 2020 12:28:17.979 [0x7f0b01cd7700] DEBUG - Sync: uploadStatus
Dec 28, 2020 12:58:17.979 [0x7f0b0111f700] DEBUG - Sync: uploadStatus
Dec 28, 2020 13:28:17.979 [0x7f0b01cd7700] DEBUG - Sync: uploadStatus
Dec 28, 2020 13:58:17.980 [0x7f0b01cd7700] DEBUG - Sync: uploadStatus```
Pull open the Synology Resource Monitor.
Watch the CPU loading.
Just because the Plex/Web UI looks idle  doesn't mean the CPU isn't doing scanning in the background  (above)
Ok. It is only running 0.1 % of the CPU. I will let it run for a while
This is after it has been running most of the day.
Thanks Chuck. Not sure how to PM you. Let me know if we can talk.
check your PM
