Got plex pass yesterday and setup plexpamp with my roku tv. I was able to control the music on my tv just fine. But today it’s no longer working. I can still see all my music and connect to the tv. But when I select music to play it just shows the loading icon. If I start music on my tv and then try to control it plexamp, I am able to use previous/next track and the play/pause controls, but nothing else works.
Anyone run into this before or have an idea why it’s not working?
Any chance of a Plexamp log after it’s been spinning?
Plexamp-Logs-2021-09-03-1.zip (22.4 KB)
Here are my logs. I let it spin for 30 seconds or so.
Hmm…
Sep 03, 2021 13:26:11.628 [0x6bcdf000] DEBUG - Networking: Completed request 65: (GET http://192.168.1.2:8324/player/playback/playMedia... with code -7 (have 0 bytes) in 0 ms.
Any idea what lives at that IP? Is that your server?
192.168.1.2 is my Roku TV
192.168.1.13 is my server
I’ve tried resetting everything and it still doesn’t work. Deleted and redownloaded the Plexamp and Plex Roku app, as well as restarted my server. Any ideas on what I can try doing? Or any settings to check?
Is there any more info I can provide that would help diagnose this problem?
very dumb question here.
Are you on the same network? Is device running plexamp and your server on the same wifi or same wired connection?
Yeah, everything is on the same network. The Roku tv and the server are both connected by ethernet. Plexamp is running on ios and connected by wifi.
(edited for clarity)
